10-01-2017, 04:25 PM | #1 |
328
Rep 742
Excessive inner tire wear on front tires?
Hi everyone, tires have about 8,000 miles on them. Front right is showing cording and front left is pretty much bald on the inside. Alignment was performed about 10-12,000 miles ago. Past 8,000 miles has been half freeway and half spirited mountain driving.
Info on car: h&r race springs, 265/30/19, 295/30/19 Hankook ventus v12 evo2 tires. Does this look normal? I know that when lowered wearing on the inner front tires but this seems a bit crazy as the rest of the tire has lots of life left. |
10-01-2017, 04:27 PM | #2 |
Stop the hate, get a V8
3850
Rep 8,625
What were the alignment specs when you had it checked?
Past: 2011.5 M3 sedan ZCP |
10-01-2017, 04:28 PM | #3 |
328
Rep 742
10-01-2017, 04:34 PM | #4 |
11586
Rep 12,728
could be a few things. first, lowering springs may have added some rear camber. second, you should check your rear toe settings. a slight toe-out in combination with camber will compound this. lastly, this is where the car pivots when you are turning and accelerating and engaging the lsd. if you're making a tight right turn from a stop and getting on the gas pretty good (like city driving), you're going to induce some wear.
although your tires are shot (i can see belt in the last pic), 8,000 miles isn't terrible when all of the above is contributing. edit- just realized these were the front tires. its probably from a toe-out alignment.
Instagram; @roastbeefmike
10-01-2017, 04:38 PM | #5 | |
328
Rep 742
10-01-2017, 04:43 PM | #6 |
11586
Rep 12,728
did you replace your rear tires at the same time? usually, you'll replace the rear tires 2:1 to the fronts on these cars. if your fronts look like that, but your rears are fine, it is a toe issue. if your rears are shot too, you're over-driving the tires.
10-01-2017, 04:47 PM | #7 | |
328
Rep 742
10-01-2017, 05:05 PM | #8 | |
3850
Rep 8,625
What were the alignment specs?
10-02-2017, 08:39 AM | #10 | |
3850
Rep 8,625
Toe eats tires faster than camber.
Edward376.50 |
10-02-2017, 10:01 AM | #11 |
2760
Rep 5,483
Toe plus camber = tire death. I run a little bit of front toe out and 2.5 degrees and if I don’t rotate I wear insides quickly. I have found the alignment makes the front end respond so nicely that it is worth it to rotate and run square. Used to be a big believer in staggered. Now I think I would just add a rear spacer to increase track width in back to cure any oversteer from the square setup
10-02-2017, 11:00 AM | #12 |
3943
Rep 3,988
Get a new alignment shop.
They fudged the results and didn't do a good job. Do you have the print out? Did they give you one?
10-02-2017, 01:43 PM | #13 | |
328
Rep 742
10-02-2017, 02:26 PM | #14 |
3943
Rep 3,988
Well there is really not much you can do about it now, replace your front tires and get another alignment done. This time make sure to goto a good alignment shop. Ideally you want toe to be as even as possible and closer to the 0 end of the specs. If they left it at the upper end of the specs, it could still be within spec and cause premature thread wear. The specs call for more toe in than needed imo, it is good for safety (bmw avoids lawsuits) because it promotes understeer at the expense of tire wear.
I like my front toe as close to 0 as possible, usually 0.05 degree each side or 0.1 total. (0 toe on track cars) You also want me to make sure camber is even and isn't out of wack which could mean something is bent.
10-02-2017, 04:43 PM | #15 |
399
Rep 852
I had the same issues in terms of wear. Ran stock sizes of Yoko AD08R. Front right or left was down to cords and other just worn no cord. Backs were bald no cord.
A friend that works at a Euro shop told me this is a common wear pattern of euro vehicles. |
10-04-2017, 02:31 PM | #16 | |
3850
Rep 8,625
"Common wear pattern of Euro vehicles"? That doesn't make sense.
10-06-2017, 12:31 PM | #18 |
377
Rep 2,982
Too much toe out for sure. I bet your car is darty and skittish when you brake hard too right?
You're dragging the inner shoulder hard. It's kind of like if you were knock kneed and never lifted your foot during your stride so the inner part of your shoes would be wearing. |
10-07-2017, 05:30 PM | #19 |
11586
Rep 12,728
might be 1/2 right... most euro cars are front engined and rear wheel drive. they have some toe out from the factory because it makes it easier to recover from oversteer. zero toe, or toe-in makes the handling more responsive and sometimes referred to as "twitchy." its not an accident that these cars understeer and have a toe-out; they are easier for the average joe to handle when he screws around and bites off too much.
