09-25-2017, 09:19 AM | #1 |
Digger
209
Rep 2,619
2003.5 M3 Street/Track Car *LOW MILEAGE*
Never thought the day would come however, its time to move on from this beast. I am simply not enjoying it as much as I should and its a shame to keep it in the garage just to stare at when the door goes up and anytime I'm out there.. Title in hand. I bought this car several years ago with the hopes of being able to track it heavily. Its become much more of a static display car at car shows and in the garage. For a E46 M3 this is also a cream puff mileage wise with now just over 33,000 on the clock. Having said that, I did actually take it out for the first time in a year and it's running exceptionally and strong. This car is setup perfectly, and has had no expense spared in modifications. It pulls with intensity with the 4.10 differential and the SMG modifications make it a lot quicker (Spare me the SMG comments please... This isn't the OEM Version..). It also corners like a beast, suspension is quite in tune, combined with the aero pack puts it on rails. Have plenty of extras that can be bought with the car as well, mainly wheels and tires Open to reasonable offers. *Pictures can be found with the link below* https://www.dropbox.com/sh/3zht82jqd...0M1Extb_a?dl=0 Exterior: - Gloss Black Grills - Predator Angel Eyes - APR GTC-300 Wing - APR Splitter - Aero Catch Latches Suspension/Wheels: - Apex ARC-8 18x9.5 Satin Black (Current Setup) -Macht Schnell Stud Conversion - Moton Clubsport - GC camber/caster plates GC RSM and rear spring adjusters -Eibach springs -Rogue Engineering Race Brace - GC front and rear sway bars, and adjustable end links - Powerflex FCAB and RTAB - Turner rear lower trailing arms (camber adjustable) Drivetrain: - AP Racing Brakes 6/4 Piston - Carbono Intake - Diffsonline 4.10 Custom LS Diff - JB Racing lightweight flywheel, CM segmented Kevlar clutch - AA DME reflash - Jet Hot Header, Larini High Flow Cats - UUC Rear Exhaust - Custom Painted Valve Cover - Heat Foil Wrapped Air Box Interior: - Sparco Pro 2000 seats - Sabelt 6-pt harnesses (HANS on driver side) - Custom BimmerWorld Four-point roll bar - AIM Solo DL w/ Canbus connection included) - Sparco Wheel - Sparco Hub - Rogue Engineering Quick Dis-Connect -Custom Horn button
2009 E92 M3 /// Melbourne Red /// Fox Red /// M DKG
Full Innotech Exhaust - DINAN Intake - IND Engine Bay Appearance - IND Hand Stitched Boot Covers - and much more.... Last edited by SchnellM3; 09-25-2017 at 09:34 AM.. |
Tags |
coupe, e46, e46 m3, track car |
