09-07-2017, 10:11 AM | #2 | |
Boost
1354
Rep 3,692
Drives: 135i M-Sport
I went with a different brand used, they're still in packaging
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
09-07-2017, 10:36 AM | #3 |
///M Powered for Life
11490
Rep 10,329
I have the front brake arm solid bearing from BW on two cars. It works wonderfully and is totally street friendly
09-08-2017, 07:13 AM | #4 |
126
Rep 938
09-09-2017, 06:22 PM | #5 |
11490
Rep 10,329
that isn't the technical name. It's the bushing that goes on the arm that goes from the front hub to the frontal area of the car
09-09-2017, 07:43 PM | #6 | |
Boost
1354
Rep 3,692
Pretty sure you've referring to the "upper control arm bushing" (inner position). A lot of track-rats will go with a monoball in that location. If you DD you'll want to leave it stock. This mod added more NVH than any other mod I've done to my car, going to align the car (this may be the cause of some NVH?) and hit the track next week - hopefully with improved braking stability/turn in and steering response. This is the bushing that I had for sale... unfortunately I have returned it to HPA as I went with Rogue Engineering.
09-11-2017, 07:52 AM | #7 | |
11490
Rep 10,329
http://www.bimmerworld.com/Suspensio...93-M3-E82.html This hasn't added any NVH to either of my cars and I'm super sensitive to it |
meko178.50 |
09-11-2017, 06:19 PM | #9 |
1889
Rep 5,506
If you are planning to track the car, front camber plates are a great upgrade. The factory adustment will take you to -1.5 degrees camber only. On track, the tire was rolling onto the sidewall under cornering even with high tire pressures.
Dinan fixed camber plates are only $200 and a worthwhile upgrade. Probably the best $200 upgrade I've added in a long time.
Auto Detailing Enthusiast!
09-11-2017, 06:23 PM | #10 |
503
Rep 1,055
I'd like to do the same but part of the problem for me while researching has been that many of these parts are called different names by different people/web sites. Ex. Tension struts/upper control arms/inner control arms
09-11-2017, 06:31 PM | #12 |
1889
Rep 5,506
I'd think that's the most obvious answer... but the OP's suggestions seemed more "in addition to coilovers" kind of upgrades.
But if the OP doesn't already have coilovers, that would be the first thing to do.
09-12-2017, 06:36 PM | #13 | |
190
Rep 969
Sold 2011.5 E92 M3 ZCP.
cenix379.00 |
09-12-2017, 09:19 PM | #15 |
11586
Rep 12,728
not for everyone, but one of my favorites.
Instagram; @roastbeefmike
09-13-2017, 11:24 AM | #16 | |
2760
Rep 5,483
Coupling the Dinan plates with one of the coil systems designed to be used with the stock upper mounts would make for a pretty idiot proof street coilover system, and with some front lowering you would still be able to get to -3 or so. I'm at -2.5 with stock springs and the Dinan plates maxed out. Caster wise, these things are ~7 from the factory, not sure how much more caster you want with a 12.5:1 rack ratio for a dual duty car, but I could see wanting more to get the most from the tires
