08-17-2017, 04:12 AM | #1 |
777
Rep 1,923
Front lifting on high speed corners
I know I will get a lot of different opinions, but I wanted to know why you think is doing that and how to fix it.
Got some opinions already, but happy to hear some from here Set up: 500/550 lbs hyperco springs Jrz rs pro Hotckis front sway bar and no rear bar Camber shouldn?t matter here. Obviously the car is understeering on high speed corner due to the lift. Thanks!
08-17-2017, 08:16 AM | #3 |
11817
Rep 23,187
08-17-2017, 09:03 AM | #4 |
11586
Rep 12,726
i presume the car was corner balanced? do you think that took away from the front end rake and transferred the lean to the rear?
another thing that comes to mind is caster. has the caster been changed in a way that when you turn, the front tires want to "stand on their tippy-toes?" i don't have any real world experience with this, these are just my initial thoughts. interesting subject.
Instagram; @roastbeefmike
08-17-2017, 09:18 AM | #5 |
448
Rep 1,263
08-17-2017, 09:52 AM | #6 |
2760
Rep 5,483
Check front bar for bind (looks like essentially no droop travel?), more rear spring are the first places I'd look. I bet if it's only happening in high speed corner your wing and diffuser are just too much for the front aero to handle, the Z4 body seems lifty up front
We were just talking about bumpstop tuning on aero cars lately in another thread
08-17-2017, 09:55 AM | #7 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
Need less front rebound.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
08-17-2017, 10:35 AM | #8 |
777
Rep 1,923
No curb.
08-17-2017, 10:45 AM | #9 |
346
Rep 396
Yeah, that would explain the understeer. Maybe try rear sway bar, higher spring rate, lower front ride height - some combination of those. What kind of tires are you running? Front splitters need low clearance otherwise they lose a lot of the downforce.
08-17-2017, 11:58 AM | #10 |
2760
Rep 5,483
static ride height seems fine. Makes me think aero at 90+ coupled with not enough rear spring could be changing rake especially if not a true coilover The track appears to be falling away there too, could just be asking too much from the car
nholmes542.00 |
08-17-2017, 03:36 PM | #11 |
1821
Rep 5,337
Riverside/Telledega counter-clockwise? There's a slight bank/camber in towards the apex. Track's not falling away, might be a trick with the angle in which the photo was shot. I suspect the "lift" is more of an optical illusion because that turn places tremendous amount of load to the outside tires, thus with the rear having no swaybar, the inside wheel extends fully to remain in contact with the ground while the front inside is lifted off of the ground due to a combination of not enough rebound control AND stiff front swaybar AND no rear bar in comparison.
08-18-2017, 09:42 AM | #13 |
5355
Rep 2,806
Drives: '09 E90 M3 - IB
Based on the couple pix I've seen of your car, you must have a TON of rear grip. You have a big rear wing, a rear diffuser and no rear sway bar. How are you balancing all this out in the front? In my opinion, you're not. The simple front splitter on a stock bumper is not enough given the powerful rear setup. The proof? The picture showing you driving on three wheels under high speed, high-G situations.
The tools you can use to combat this lifting wheel are: (in order that I would try) -Reduce stiffness of front sway bar (if possible): Reducing stiffness of the front sway bar could reduce inside wheel lift on rounders like this. -Lessen Angle-Of-Attack of rear wing: Reducing AOA of wing would reduce pressure on the rear of the car which would allow weight and grip to return to the front and reduce understeer in general. (I believe that right now, you have more rear grip than you need---that this car is so rear-focused, that the front is literally lifting in the air.) -Stiffer rear springs: Stiffer rear springs might be able to give the rear of the car a bit more support given the huge forces happening in the rear. And at the same time shift weight to the front. -Put a sway bar in rear: A rear sway bar could share the duties of leveling the car with the front sway bar. This would reduce the amount of work the front sway bar has to do. I went to the Hotchkis website to check out your sway bar. Hotchkis doesn't specifically make a sway bar for a Z4M. Which version of Hotchkis sway bar are you using? The E46 M3? Even if it does generally fit, who's to say that the stiffness of the bar is appropriate to your car? The Z4M is lighter than an E46 M3. And if you've lightened the car even further for tracking, perhaps this bar is just too stiff for a light Z4. Plus, given that it's the only sway bar on the car, the duties of keeping the car level on a long turn like Riverside are falling on the outside springs/dampers and the front sway bar. No rear sway bar to help. I think the front passenger damper is compressing so far and the sway bar is so stiff that it's just lifting the inside wheel. As Richbot mentioned, there doesn't seem to be any droop happening with the wheel that's in the air. This means that it is actively being pulled upward. The only thing that could pull that wheel upward so hard would be the sway bar. I think a combination of the four things mentioned above can bring more balance to a car that seems to be very rear-focused. (I can share some other thoughts if you're interested.) |
08-18-2017, 11:40 AM | #14 | |||
777
Rep 1,923
Caster? hmm I have about 6.7 caster.....not sure if that can affect in anything, but something to consider =) Quote:
I could do 2 things here. 1. add rear sway bar + add 100lbs springs in the front to try to keep the car balance the way it was without the rear sway bar Quote:
yeap...that is one of the things to change. I was running +11 front and +10 rear, because I like the front grip coming out of the corner, but now I need to go less in the front I am running pirelli slicks....your tips are what I heard too....thanks!
08-18-2017, 11:41 AM | #15 | |
777
Rep 1,923
08-18-2017, 11:53 AM | #16 | |
777
Rep 1,923
Hey, The car doesnt have a TON of rear grip, this car is loose in the rear by nature.....aerodynamics are the minimal issue here....the main issue is what you said....either soften front sway bar, I was in medium setting, add more spring rate in the rear, or put my rear sway bar back on.. Putting the rear sway bar back is the last alternative since this car tries to kill me when I have them on I like to test my car one change at a time....so for now I will soften the front sway bar, and lower front rebound....if its still lifting, I will add rear spring rates.....and if its still not working, I will put my rear sway bar back, and increase front spring rate. About hotckis you are correct. Its an m3 e46 sway bar,. However both OEM sway bar is the same 27mm. The hotckis is only 3mm stiffer in the soft setting. the e46 is only about 100lbs heavier than the z4m. thanks for the observations!!
08-18-2017, 02:17 PM | #17 | |
5355
Rep 2,806
At low speeds, I agree, aero requires minimal thought. However, at high speeds, aero is quite formidable and needs much more consideration. Don't underestimate all that aero you have on there! I totally understand if you say the car is loose at low speeds. My E90 M3 became loose too after it was gutted and caged since most of the weight came out from the rear and the cage stiffened the chassis. The aero is a big fancy decoration at low speeds. I still fight looseness at slow speeds. Exiting a tight corner requires patience, a smooth throttle and grippy tires to really put power down. The Off Ramp corner is a constant source of challenge. (And the pavement there doesn't help.) But, I would be VERY VERY surprised if you said the car, with this setup, is loose at high speeds. I mean, c'mon, you have a big rear wing, a rear diffuser, no rear sway bar and only 550 lbs springs. If you are going near 100mph at the apex of Riverside, you are generating a TON of downforce on the rear in that turn. On high speed rounders, like on Riverside, I believe the rear aero is a very large consideration. And it is worth noting that Riverside is a bit unique. In California, the Riverside turn is perhaps the most prominent example of a basically flat, very high speed, long, fairly steady rounder. No other track around here offers the same scenario. Big Willow Turn 2 is going up a hill. Big Willow Turn 8/9 is probably the closest. It's faster and flat but isn't a steady single turn because you can straighten out the middle of 8 and then Turn 9 is decreasing radius. ACS has higher speeds and a steady loading on Turn 1/2, but it is a banking Nascar Oval so there's a whole lot of other things going on there. Chuckwalla doesn't offer speeds as high on it's flat rounders. No on Thermal. Moving further away----No at Laguna Seca. No at Sonoma (Turn 6 goes downhill). Thunderhill's Turn 2 is fairly similar, but even then the speeds are still slower (more like Chuckwalla). Anyway, all this to say that if your car is presenting some seemingly odd challenge at Riverside, part of it is due to the fact that the car doesn't see this exact combination of parameters many other places. In this picture, I'm guessing you are around 100mph on Riverside. This is THE defining moment where all that rear downforce should shine and become formidable. And I would say, looking at your picture, it is doing exactly that (along with all the other factors we already mentioned). And one last thing to consider (which usually should be a primary consideration): weight transfer based on gas/brake pedal activity----on Riverside, I'm always trying to be on the gas if possible. This is one more thing to shift even more weight to the rear of the car. |
08-18-2017, 03:41 PM | #18 |
2760
Rep 5,483
I'm not saying the aero is necessarily lifting the front of the car. Who cares what the car's attitude is through the corner if it's fast? Nobody, that's who. I'm saying higher speed understeer = aero imbalance, IMO, and aero imbalance piled on top of soft rear springs and no rear bar means lots of rear grip and more the faster you go. Lifting an inside front once in a while doesn't necessarily mean the suspension is set up poorly, especially with a steampunk horse and buggy E46 front suspension
I'm not a fan of big rear bars on cars like ours, so I agree leave it off if you can get away with it, and I think you can if you up the rear spring some
Chuck's M3162.00 |
08-18-2017, 04:52 PM | #19 | |
3221
Rep 6,218
08-18-2017, 05:02 PM | #20 | |
777
Rep 1,923
im going probably at 60-70 mph dogbone
08-18-2017, 05:18 PM | #21 | |
777
Rep 1,923
Its amazing how I thought riverside was flat too, but when you walk at the track, you will get shocked how banked the turn is....specially if you stick to the center on the turn.....outer part of the turn is pretty much flat. anyway, i take riverside at around 109. I know aero makes a huge difference at 100+mph, but trust me....its not the main factor of the lift.....not that I mean it doesnt have any affect....its has some....but the main reason is due to no rear sway bar, and soft springs combo in the rear, and not due to the aero.
08-18-2017, 05:41 PM | #22 |
1821
Rep 5,337
Ah. Okay, then the track is definitely falling off there.
