08-14-2017, 03:47 PM | #1 |
Rep 35
Stock Down pipes? Decat / Removal
Hi,
I'm thinking of gutting my stock downpipes. Has anyone got any advice? I have a few questions. How much more power will it give me? Currently running 720DMS Map and Eisenann mid pipe, with stock rear mufflers. Can I delete the cold start with no issues? What happens with the sensor? Is it much more beneficial buying new Down pipes? Will it be ridiculous loud even with running the mid pipe and stock rear mufflers? I want the crackle and bang from the de-cat, but want to tame it a little. Any experiences and advice ??? Would be grateful Thanks. |
08-17-2017, 02:50 PM | #5 |
BigMacs
69
Rep 492
Drives: 2019 BMW M5
Gutted stock downpipes are much quieter than aftermarket ones due to design and fitment. I had the Armytrix downpipes on my car with the full Armytrix. Very loud and aggressive. I put stock gutted downpipes back on the car with the Armytrix, and it was much, much quieter. Also, the wastegate rattle I had pretty much went away or is far, far less noticeable now.
-James
2019 M5 : Black Sapphire Metallic / Black Full Merino / Carbon / B&W / Executive / Driving Assistance Plus / BMW Performance Carbon Fiber Front Splitters, Side Skirts, Rear Diffuser, Trunk Spoiler
2020 RDX A-Spec : Apex Blue Pearl / Red |
08-17-2017, 07:03 PM | #8 |
Joint Chiefs of Staff
24330
Rep 191,080
No point in doing so for couple reasons.
1- More labor with a risk of ruining the downpipes 2- Does not make sense financially. It is against the law to sell your car without emission legal downpipes. So eventually you will need to buy a set of OE downpipes which will end up costing you more than aftermarket ones.
08-17-2017, 07:21 PM | #9 | |
121
Rep 411
You can buy a used set of OEM downpipes on here for $400-$500. It makes more financial sense to go this route, as you'll save yourself at least $400. Fitment is spot-on and they're double-walled. Installation is a breeze. |
550Reasons149.50 |
08-17-2017, 07:26 PM | #10 | |
24330
Rep 191,080
08-17-2017, 07:35 PM | #11 |
121
Rep 411
08-17-2017, 07:36 PM | #12 |
24330
Rep 191,080
you dont need to have them wrapped.
08-17-2017, 07:40 PM | #14 |
24330
Rep 191,080
Same reason why would not need to coat or wrap any other catless downpipe
08-17-2017, 07:46 PM | #16 |
24330
Rep 191,080
There is no benefit in doing so for daily drivers
08-17-2017, 07:48 PM | #17 |
121
Rep 411
These downpipes run directly behind the rear cylinders. Do you want the excessive heat transfer? I sure don't. Anyone who has experience with this engine will certainly advise you to wrap or coat the downpipes on this platform.
08-17-2017, 11:30 PM | #18 |
431
Rep 2,062
This ^ and it's been proven on here that they need to be wrapped or coated if they're not stock. Mine doesn't make money telling us otherwise.
08-18-2017, 01:31 AM | #19 |
24330
Rep 191,080
Can someone post a link of the thread where they did these tests?
08-18-2017, 05:17 AM | #20 | |
121
Rep 411
Wrapping or coating the downpipes is also going to keep that excess heat out of the engine bay, while slightly reducing heat soak. It will also retain heat in the exhaust. Hotter gas flow faster than cold gas. This is all common sense. How about you do some tests yourself and prove my theory wrong. It makes more sense to wrap or coat the downpipes given their location. I can't imagine that heat doing anything to help the engine run more efficiently. Some of the more experienced owners can chime in, but I'm sure the top guys will agree that you will need to wrap or coat the downpipes. You're giving bad advice. I would stick to selling parts. |
08-18-2017, 05:19 AM | #21 |
121
Rep 411
By the way, I'm sure you can find plenty of test results of before and after temps through the companies that manufacture the wrap or coating. A test on this platform is going to give you similar temperature results.
08-18-2017, 08:21 AM | #22 |
644
Rep 2,039
"We also offer ceramic coating services on these utilizing Cerakotes High Temperature Ceramic coating, made to withstand temperatures up to 1800F. Please note that while we do offer a lifetime warranty on the downpipes, we only offer a 1 year warranty on the ceramic coating services due to the nature of the product."
https://www.x-ph.com/vrsf-3-stainles...-11-bmw-m5-m6/ |
