BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      05-12-2008, 04:59 AM   #1
Shade
Shade's Avatar
45
Drives: 12 AW F10 M5
Offset Question (need help!)
So i got the HRE 441 R with these spec
Offset:
38 front 19x8.5
28 rear 19x10.0
Tires:
Toyo T1R
245/35/19
275/30R19
Do you guys think it will fit my E92 M3? thanks
08 E92 M3 AW M-DCT
09 INDxRENN-SPEC Project GT-R
      05-12-2008, 02:34 PM   #2
brandon @ eas
BimmerPost Supporting Vendor
brandon @ eas's Avatar
517
Drives: F30 335i
the front is going to be WAY tucked in. You will need a 30mm spacer in the front to make that work. The rears should be ok, probly still tucked in a little though
      05-12-2008, 03:06 PM   #3
Shade
Shade's Avatar
45
Thanks ! brandon, i am going to give HRE a call and see what they can do to change the offset. I love those wheels and i dont want to loose it.
08 E92 M3 AW M-DCT
      05-13-2008, 09:17 AM   #4
ben@tirerack
M3Post Supporting Vendor
87
Drives: 740i
You may not need quite that much spacer. The stock M3 18" wheel is the same 8.5 width and 29mm offset, which is 11mm different. Asi it stands, your HRE will be tucked in a bit, and you may need more spacer depending on brake clearance. 30mm spacer would give you an effective offset of +8, which would be on the low side.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions.
      05-17-2008, 11:14 PM   #5
///MML
///MML's Avatar
45
Drives: e92 M3
Offset:
38 front 19x8.5
28 rear 19x10.0
Tires:
Toyo T1R
245/35/19
275/30R19
the correct RR tires are F: 245/35/19, R: 275/35/19
2022 M240i | Brooklyn Gray | Red Leather | Black 791M rim| Black trim | HK | Premium | M Lum
m3post
