08-12-2017, 10:32 PM | #1 |
657
Rep 1,749
Auto Club Oval (or any Oval)
I am heading to the Auto Club "Roval" in Fontana CA next weekend. It is the NASCAR oval circuit that was used in the movie Days of Thunder back in the day. I am not sure if it is currently on the NASCAR schedule or not but essentially it is a huge oval.. There is a road course in the middle of the oval and speed ventures set the course up where you essentially drive around 3/4 of the oval and then cut in and drive through the road course and then back on the oval. Hence "Roval"
Speeds hit about 160 mph around the banked oval. I am just wondering if there is anything I should keep in mind in terms of oil starvation risk in the situation where you are doing high speeds on a banked oval for a consistently long period of time? Anyone ever driven an oval like that in their e92 m3? |
08-12-2017, 10:56 PM | #2 |
11586
Rep 12,726
yes, it is still a nascar track, and many people on here have driven on it. our cars will do about 140ish. speedo will show a lot higher, but its about 140.
if you're dct, you'll be at the top of 6th. nobody has had any issues that i know of, however, it has been said that with sticky tires, one would be able to exceed the oil pump g force rating. you're really only sucked down for about five seconds.
Instagram; @roastbeefmike
08-13-2017, 02:20 AM | #4 |
5355
Rep 2,806
Drives: '09 E90 M3 - IB
I drove Auto Club Speedway's Roval Course a couple times in June with my E90 M3.
I've written a few things about it since. I talked a little bit about the general course here: http://www.m3post.com/forums/showpos...postcount=1814 I talked about the braking zone into Turn 3 to exit the Oval here and how challenging it is to get right: http://www.m3post.com/forums/showpos...&postcount=437 People have asked about oil starvation in the past. No oil starvation issues as far as I know. However, I will say that all of the strangest tech issues I have ever experienced have all happened at Auto Club: -I've blown a fuse while going 130mph on the Oval which caused the engine to stop functioning and I had to coast into the infield and get towed into the paddock -The pressure switch on my misting system suddenly stopped working there -With front aero, my bumper was pulling downwards in general. The sustained high speeds on the Oval along with the front aero caused the outer edges of the front bumper to pull down even more. This caused a metal bracket between the bumper and fender to bend downwards (more than it had been). That bracket had a sharp point on it and it became a cheese grater on the outer edge of the passenger-side tire on the Oval and damaged it. -In June, I lost my entire air filter and air intake hose for my supercharger somewhere either on the track or the paddock. I didn't even realize it and kept running without it. I only experience weird stuff like this at Auto Club. Nothing like this happens at any other track. The Oval is the fastest section of track pavement in California. Between the bank and the high speeds, the car is subjected to unique forces that you just don't see anywhere else locally. It is an interesting track with unique challenges, although I find the most interesting challenges to be on the Oval (the nerves of Turn 1 and the braking for Turn 3). The Playground section at the end before returning to the Oval feels like a poorly setup auto-cross to me.....bad pavement, pot holes, people hitting the cones so they're in you're way....the Playground is definitely my least favorite section. Anyway, I hope you have fun! (and have less tech issues than me!) Here's one of my laps to give you an idea what it looks like: |
KillBill99913.50 |
08-13-2017, 06:00 PM | #5 | |
657
Rep 1,749
08-14-2017, 02:24 AM | #6 |
892
Rep 9,032
If you run with Euro MDM, turn 1 and 2 will set off the DSC light due to the difference in wheel speeds on the inside and outside wheels. This causes a wiggle as you're driving around the banking. NOT FUN.
For the first chicane after the big U turn, you'll feel a slight dip on the RIGHT side of the car at turn it. Turn in at that dip and floor it. You'll fly thru there. The penis turn has 2 lines. A wider turn with a apex at the back of the turn or a "racer line" where you dive in and do a V turn. It's a fun track but the banked turn is not fun at all for me, particularly after the power steering belt snapped at turn in on turn one. The steering a a bitch, even when dong 130. . .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
macdude357467.00 |
08-14-2017, 10:55 AM | #7 | |
467
Rep 818
08-15-2017, 02:26 AM | #8 |
2147
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
Here's my lap in my more mortal E92 before I stripped it and added coilovers. dogbone is the fastest e90m I know there. Stock interior at this point, just BBK and light suspension mods (camber plates, dinan sway bar, swift spec r springs on oem ZCP suspension):
You will want to be careful of a few points on the track that will bend a rim if you go beyond the track limits. I have a couple friends who fell victim - the end of the rumble strip in turn 4 is notorious for this ( the first right hand turn you make after the left turn you make into the infield). Turn 6 exit too. Before you reemerge onto the bank oval, the parking lot area that is usually coned off so you can make a wide left hand turn through it is also paved particularly poorly.
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
08-15-2017, 05:20 AM | #9 | |
892
Rep 9,032
macdude357467.00 |
08-15-2017, 11:59 PM | #10 | |
3431
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
I'll be there Sunday with a few amigos. Have fun.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
redpriest2147.00 |
08-16-2017, 01:09 PM | #11 |
3221
Rep 6,218
DO NOT DO THIS
Here's an older slow video that shows the difference between what your speedo will say in the car versus actual GPS speed (what you are really doing) as roastbeef posted above.
08-16-2017, 01:14 PM | #12 |
3221
Rep 6,218
Here's a broken wheel from said rubble strip mentioned above. Sadly this was my second wheel to fall victim there.
08-16-2017, 01:27 PM | #13 |
424
Rep 1,325
+1. Victim here too. Be on the lookout for rumble strips. The ends have a sharp drop off.
