08-02-2017, 01:15 AM | #1 |
13
Rep 22
Extreme rubbing issue with front 275/35/19 tires on square Arc-8's
Running Firehawk indy 500 tires, stock suspension but slightly lower due to ZCP. Wheels are 19x9.5
I am having extreme rubbing issues with the front tires, turning into parking spaces is damn near dangerous because the front tires get stuck. It's not so much the fenders, but more so the inner wheel well. Any advice on how to get rid of it? I'm considering just throwing my 255's back up front, a little chunk of front tire fell off shortly after putting the new tires on. |
08-02-2017, 01:20 AM | #2 |
Watch This!
33
Rep 705
You wont be able to run a 35 series with the width of a 275. I had the same problem on mine... although I did get away with it on a Falken tire but for the most part most brands will be to tall with the 35 series. You'll have to go to a 275/30/19 to clear the fender liners. ... I was only able to get a 255/35/19 to fit up front with a normal size brand other than the Falken.
08-02-2017, 01:24 AM | #4 |
Watch This!
33
Rep 705
Also I've always run a 275 on my CCWs upfront but a 35 series for most brand tires is just to tall. You'll need to switch to a 30 series on a 275 to clear.
08-02-2017, 01:28 AM | #5 |
13
Rep 22
Hmm, would you recommend playing it safe and going with a 265/30? I'm worried that I'll still rub and have four tires just sitting in my garage waiting to go to the rears.
08-02-2017, 01:29 AM | #6 |
13
Rep 22
08-02-2017, 01:39 AM | #8 | |
13
Rep 22
08-02-2017, 01:52 AM | #10 | |
13
Rep 22
Some driving videos on my Instagram @Jon_mendez Going to Thunderhill August 5th to really test them out |
08-02-2017, 10:19 AM | #11 | |
Pingu
237
Rep 484
08-03-2017, 04:16 PM | #13 |
Watch This!
33
Rep 705
It's up to you at this point but depending on the offset, I still think keeping the 275 and just going to a 30 series would be fine. I have a set of track rims and tires and I do 255/35/19 and 285/35/19. The 265/30 would clear no doubt.... as far as going 265/30 you'll be just fine plenty of clearance.
08-10-2017, 02:55 PM | #16 |
Admiral
931
Rep 3,886
35 is too big.. needs 275/30 as mentioned above
2020 FORD RAPTOR 2014 F15 X5 | M-SPORT SOLD 2011 SG E90 M3 | 2008 AW E90 M3 | 2004 E46 M3 |
