XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      08-01-2017, 04:09 AM   #1
gettinOld
Drives: 2014 X1 xdrive28i M Sport
Highway driving and a whining
14 28i xdrive w/ 50k miles
Lately, I have been noticing a sharp whine coming from what I'm guessing is the center diff. It's very faint, but when im cruising on the highway around 70mph is when I can start to hear it over the wind and road noise. Its not a LOUD noise by any means but I don't believe a normal soccer mom or non car enthusiast would pick it up in a normal situation, especially with the radio on. Is this normal for these cars? Anyone else experience this? Car hasn't skipped a beat at all.... should I take action and have some preventative measures done? Thanks.
      08-01-2017, 12:21 PM   #2
Gamb1t
Gamb1t's Avatar
598
Drives: 330i,X1,Z4,Solstice GXP, RX-8
Could be your transfer case acting up. If you can hear the whine at that speeds over the wind noise etc. then it's abnormal. How about at slower speeds? Revving it up at idle?
Bring it in be it BMW dealership or indie shop.
      08-01-2017, 06:20 PM   #3
gettinOld
I hear it when the car is decelerating from a higher speed. Like I mentioned if some other person is in the car they wouldn't even hear it or know it was happening. It's an "enthusiast" type of thing where we all hear the smallest strangest noises....
      08-01-2017, 06:36 PM   #4
0w40X1
34
Drives: 2014 BMW X1 s28i M Sport
Known trouble with the X1 xdrive; the front transfer case can leak, whine, need rebuilt, etc.
Also, check and make sure tires are same wear depth all around.
It might be possible to stop noise by rotating tires front to back.
It sounds like the fronts are slowing more than the back on decel so it whines.
Rears should be slightly smaller slowing down more.
      08-01-2017, 08:04 PM   #5
gettinOld
Copy that. I'm staggered with the 225Ms as it is an M Sport. I guess I have to measure tire depth. So I have to change all 4 tires when the rears disappear after 10k miles? I don't drive spirited either and I can't stand the RFT.
      08-01-2017, 08:06 PM   #6
gettinOld
btw.... Thank you for the responses gentlemen! I was under the car the other day changing oil and I did not see any fluid leaks at all.
      08-02-2017, 09:55 AM   #7
0w40X1
34
If you are staggered the 2 different sizes are a close match not exact.
Maybe you Xdrive guys can find out which pair needs to be larger and slower turning.
I suspect the fronts should be.
So, on my staggered s28i with 8x 18 and 9x18 355m wheels, I'd put Michelin PSS of 225/45r18 (25.9 inch diameter) and 255/40r18 (26.0 inch diameter) if I stayed same as stock without run flat.
I'm gonna down gear approx 4% with 225/40r18 PSS (25.1 diameter) and 255/35r18 (25.0 diameter).
Notice the stock sizes have the front tires rolling slightly faster, while the lower profile set I'm putting on has the front tires rolling slightly slower.
      08-02-2017, 10:53 AM   #8
Gamb1t
Gamb1t's Avatar
598
Sure it's not the turbo whistle?
Not sure your car's mileage, but it's good to change the TC oil out if you haven't. It's tricky but not super hard.
Based on realoem, I deduced the BMW had a few revisions of the TC over the years.
      08-07-2017, 10:12 AM   #9
Musiclover1013
Drives: 2013 X1
Could be the front differential
Saw your post. I just had to have my front differential replaced due to the same sound. My 2013 X1 has 51,000 miles on it. Just noticed a whining sound late last week that only happened on deceleration at speeds 75 down to about 64. Thank God for my CPO warranty as the damage would have been about $2,900. My dealer said that this was the 2nd one they've replaced in the X1 in about 30 days. Good Luck.
      08-07-2017, 08:03 PM   #10
der_kommissar
16
Drives: 2015 Midnight Blue X1 xDrive28
2007 328i  [0.00]
I had that sound in my '15 x28i earlier this year and had the transfer case replaced under warranty. Get it in ASAP and hope you can get it done under courtesy from the dealer.
      08-07-2017, 08:22 PM   #11
gettinOld
Over 50k unfortunately.....
      08-08-2017, 09:52 AM   #12
der_kommissar
16
2007 328i  [0.00]
If you are close to 50k and have a good relationship with your dealer, sometimes they will help you out anyway. Can't hurt to ask.
      08-18-2017, 06:12 PM   #13
Seagull
Seagull's Avatar
289
Drives: F87 M2, E84 X1
Let us know how it goes! Hope it isn't too costly!
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT
      08-19-2017, 06:14 AM   #14
mhx
Drives: Goat
Could be a wheel bearing too. You can self check this at home by putting it on a jack stand and try to wobble the wheels
Sounds like a bad tired or a whooosh whoosh sound.
Also check your center diff as stated above.
prob one of the 3:
1. tires
2. wheel bearing
3. xdrive diff
      08-20-2017, 08:15 AM   #15
gettinOld
not a wheel bearing.
      08-21-2017, 12:03 PM   #16
kiloTHREE
76
Drives: '13 xDrive28i
Huh, just for giggles I priced out a new transfer case. Just a shade under 1k, so not too bad. That's not even reman'd, brand new.
      08-21-2017, 12:17 PM   #17
gettinOld
well that's a relief to know.... i haven't heard the noise getting any worse, which is good news.
If you've ever heard a 911 GT3 Cup or any of the 911 based racecars, the transmission snouse is very similar to what I hear just not nearly as loud.
      08-21-2017, 12:51 PM   #18
kiloTHREE
76
Straight Cut Gears
      08-21-2017, 02:03 PM   #19
gettinOld
