XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      07-29-2017, 12:04 PM   #1
Ja Gio
23
Drives: X1 xDrive28i, 2013
2 new tires
2013 xdrive 28i. Running Conti DWS 06. Nails in both right-side tires - the front was just above the tread into the sidewalk, so not plugable. I got 2 new ones, thinking the new would go on the rear, the bad tire would be trashed, and the plugged tire will become a spare. Picked-up the car in the pouring rain, so didn't look close till later in the day. I was surprised they put the new tires on the front - maybe they thought it's FWD?
Question 1: New on the rear or front?
Question 2: Where to get an inexpensive rim for the spare?
Thanks!
      07-30-2017, 05:13 AM   #2
dastardly
Drives: bmw x1 e84 20d
If I was changing 2 tyres I would also put the new on the front they do most of your braking and all your steering just my $0.02 Craig
      07-30-2017, 10:10 AM   #3
PrematureApex
840
Drives: N55 X1, N54 135, s54 m3
What's the mileage/tread depth on the new ones? You have to be careful to not go too different in overall diameter for the sake of the center diff.
My X1 wears rear tires significantly quicker than the fronts...so that's at least one reason to start them off in the rear...to get them evened up with the front asap.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      07-30-2017, 10:14 AM   #4
0w40X1
34
Drives: 2014 BMW X1 s28i M Sport
Discount tire is a very good dealer in the US, and they'll put the new one on the back if it's same size all around.
The idea is that if either rear tire blows, it makes vehicle unstable, and prone to flip as it spins around.
If the front blows it just pulls hard that direction, but understeers so no spin.
Even as a tire seller we just put em where it felt right, and if I had FWD only vehicle, i think I'd put up front, and leave minimal tread on back where no wear.
      07-30-2017, 11:33 AM   #5
Portly
13
Drives: X1 XDrive28i, M2
Unless there's a major compelling reason to do it otherwise, Always put new tires on the rear. Better traction in the rear reduces the chance of spinning under braking.
https://www.tirerack.com/tires/tiret...jsp?techid=236
      07-30-2017, 01:46 PM   #6
Ja Gio
23
Although I don't have a proper tread depth measuring tool, I get the difference to be about 3/16. The new tires are totally new, 0 miles. The owner's manual is silent on the topic.
      07-31-2017, 10:25 AM   #7
Ja Gio
23
I just talked with my service advisor at my BMW dealership. He said there is no issue as long as same size tires are on the same axle. He said he typically advises that the new tires be placed on the front, but acknowledged that opinions vary.
      07-31-2017, 11:47 AM   #8
kiloTHREE
76
Drives: '13 xDrive28i
Even when comparing a BALD tire (0/32) to a brand new one (11\32). For a 225/45/18, your looking at a 2.5% (and i'm being generous with the maths here) overall circumference difference.
You'll get a larger diameter variance in the camber of the tire and how the vehicle is weighted and tire pressure. I've always believed this to be nothing but tire sales driven.
      07-31-2017, 06:57 PM   #9
PrematureApex
840
On a car with open diffs front and rear (or at least up front), that statement doesn't make a whole lot of sense. Sure, you want the tires on each axle to be equal, so you don't run into alignment/offset steering issues...but when talking about potential (as posted above, who knows if it's a valid concern, or just manufacturer overly-cautious specs) drivetrain issues, it would be the center diff that is of concern.
And for what it's worth, I've read more than a few threads about serious issues on xdrive cars running staggered setups with differring diameters at each axle.
      07-31-2017, 07:03 PM   #10
PrematureApex
840
It may be, but these guidelines are manufacturer sourced. In addition to the above-mentioned xdrive issues, I know Subarus are somewhat susceptible to center diff overheating/failure if the tires are more than 1/4" in circumference (the manufacturer's number)...which equals just a few 32nds. Now I'm with you, that kind of difference is probably present on most of the cars out there, due to uneven wear, lack of rotation etc. And with all the constant turning, etc. going on, the diffs always seem to be working...but surely there has to be at least something to it if the manufacturer is creating a spec right?
I mean, at a minimum, the greater the difference, the greater the heat/wear on the unit. Whether or not you should really be worried about a failure or not is a different story, I agree. I don't think one could argue against the fact that a LSD is going to last longer the closer each end is 1:1. Certainly it would.
      07-31-2017, 07:19 PM   #11
kiloTHREE
76
The problem is the same manufacturer changes it service intervals according to what their warranty covers or doesn't. It's easy legally to point blame to tire size difference when shit hits the fan.
      07-31-2017, 07:24 PM   #12
Ja Gio
23
Gheez, I have the BMW dealer and my 40 years in business tire guy saying "no issue". I looked around online but I could only find discussions of "potential" problems, but didn't find any with actual problems. I have a lot of respect for your knowledge, Prem Apex.
What to do? If issues arise, are there any warnings?
Thanks
