07-25-2017, 05:24 PM | #1 |
1574
Rep 1,252
removing wheel stud kit
My car came with wheel studs installed. I'd like to remove them and install the OEM lug bolts.
I assumed they are loctite'd on. After removing the wheel, can I remove them using an allen wrench up top? Or do I need to install some bolts on the threads and break them free that way? |
07-25-2017, 05:29 PM | #2 | |
BimmerPost Supporting Vendor
8211
Rep 18,823
Drives: BMW
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
07-26-2017, 08:07 AM | #6 |
721
Rep 2,342
Heat is your friend.
I bought a $30 propane torch. Heat up the stud a little and they come right out. No double nut method needed. If Stud changes are a way of life buy a stud removal socket. |
07-26-2017, 08:36 AM | #7 |
310
Rep 408
Why do people locktite wheel studs? It is completely unnecessary. Properly torquing the nut prevents the stud from loosening just like properly torquing a lug bolt prevents the bolt from loosening. You just need enough threads of the stud engaging the hub assembly to prevent the stud from being ripped out while torquing the nut and during driving. When installing the stud into the hub, you really don't need any torque at all. In practice you want some torque so that removal of the nut doesn't remove the stud at the same time.
Wheel studs are just 2 piece lug bolts. No one goes around locktiting their lug bolts (at least I hope they don't). If your stud is coming out when you remove the nut, reinstall the stud a few threads deeper. |
07-26-2017, 09:10 AM | #8 |
2712
Rep 2,371
And the other question, is why would you remove wheel studs? They make wheel changes so much easier...
2015 Black Sapphire Metallic 6MT M4
07-26-2017, 02:03 PM | #9 | |||
1574
Rep 1,252
2. Most tire shops won't touch a car with wheel studs 3. 2 points of failure vs. 1 |
07-26-2017, 03:03 PM | #10 |
304
Rep 351
I actually find it easier without studs to place the wheel up on the hub, then hold and spin to align the bolt holes vice trying to align 5 holes at the same time with studs.
Fake News 2017335.50 |
07-26-2017, 04:04 PM | #11 |
2712
Rep 2,371
I guess that's what the saying YMMV is for.
