07-22-2017, 07:21 PM | #1 |
93
Rep 253
BBS LM center mount 9.5x19/11x19
Hey guys,
recently thinking about getting some BBS LMs 19" for my 1M Coupe. Now i saw that the centers can be mounted from the inside and from the outside. I guess the 11j ET25 is mounted from the inside, the 10j ET25 outside (see: http://www.m3post.com/forums/showthread.php?t=1321024). The important question now is: Can anyone tell me whether the 11j is mounted from the inside, and if the 9.5J ET32 is also mounted from the inside? (The way BBS delivers it from the factory, i know you could change it up by yourself) Would be really happy if anyone could help me out Thanks Mogge |
07-23-2017, 05:13 AM | #2 | |
175
Rep 513
The ones that are mounted on the inside are an older version of it, says BBS when I asked. 9.5 +32 is mounted from the inside. I have a set of 10/11 +25, originally outside mounted, and I reverse mounted them myself. |
07-23-2017, 03:23 PM | #3 |
F15 daddymobile
2350
Rep 3,510
^ was just gonna give a shout out to this guy!
07-26-2017, 07:25 AM | #4 | |
3943
Rep 3,988
If you compare them to the fronts you can see the gunmetal lip by the bolts, if you look at the rears, you see the lip by the bolts which means the face is behind the lip/barrel joint.
07-28-2017, 01:32 AM | #5 |
175
Rep 513
Just for people's reference.
There are TWO part numbers for BBS LMs in 19x11 +25 for the M3. LM182 and LM281. LM281 = Face Mounted LM182 = Reverse Mounted Now, the 19x10 is LM272, which is also Face Mounted. So, if you want them to match, then the 272/281 is the best combo, IMO. You can then reverse mount them, to get 10/11 +10, and then you can still fit them with select tire choices, and camber adjustment too. |
Mogge9492.50 |
