07-17-2017, 03:59 PM | #1 |
98
Rep 149
Bumpstop Tuning
Gents,
I have a track built 135i. Noticed the most track-oriented action is here so I figured I'd ask here. Anybody look into tuning the suspension with bumpstops in addition to springs?
07-17-2017, 07:50 PM | #2 |
11586
Rep 12,726
first i've heard of it on this particular forum. wouldn't you want to avoid it? i mean, if you're not riding on springs and dampening with your valving, isn't something wrong?
Instagram; @roastbeefmike
07-18-2017, 10:55 AM | #3 |
98
Rep 149
I believe the theory behind it is that it compliments low and high speed corners with aero. With a progressive bumpstop, say 100lbs/in bump stop, you can run softer springs to be quick in the low speed corners and have the bumpstops add 'spring rate' in the higher speed corners where your aero would otherwise overpower your spring setup alone.
As an example, a time attack racer local to me, James Houghton runs this setup. He's been setting/resetting records across Ontario, Canada as well as at GridLife and Superlap battle alongside Will Au Yeung (another fellow Canadian - he's going to the World Time Attack event in Australia this year; pretty cool). I have yet to meet these guys in person so I haven't had a chance to pick their brains. Don't know how forthcoming they'd be about their setups tho. James Houghton Motoiq Article If you go to page 4, the article touches on the use of bumpstops to compliment the aero. Funny thing about his setup is his spring rates and the resulting wheel rates. They come out lower (softer) than what 'conventional wisdom' calls for in the BMW scene. Granted, the DC2 Integra has a double wishbone suspension whereas BMW is McPhereson and that plays into spring/wheel rate/wheel frequency choice. I still can't throw the theory away, though. Short video on his car. Searched google but unfortunately there doesn't seem to be much out there that pertains to road circuits.
07-18-2017, 11:08 AM | #4 |
2760
Rep 5,483
The M3 corners on the bumpstops from the factory, as do many many cars that come with soft springs from the factory but still handle reasonably well with reasonably controlled body roll. There's no other way to get the compliance trade-off cheaply
07-18-2017, 11:11 AM | #5 | |
2760
Rep 5,483
I think conventional wisdom in BMW world still bears the scars of some of the crappy suspension geometry of earlier platforms. I think there are much lower hanging fruit on most setups though
07-18-2017, 11:37 AM | #6 |
98
Rep 149
What do you mean? Other things that can be done before looking into using bump stops?
07-18-2017, 04:22 PM | #7 |
126
Rep 938
tuning in lieu of a good shock setup? I think if you have an appropriately tuned shock, with bump and rebound appropriately dialed in, you can run a softer spring to achieve the same goal.
07-18-2017, 05:58 PM | #8 |
Boost
1354
Rep 3,692
Drives: 135i M-Sport
James Houghton is a badass. That Integra he drives is a monster, think he set the FWD record at Buttonwillow?
This must be his trick... lol
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
07-19-2017, 04:53 PM | #9 | |
98
Rep 149
Not saying the records are being set because of the bumpstops but I'm sure its doing its incremental job within the entire package.
07-20-2017, 07:50 AM | #10 | |
2760
Rep 5,483
EDIT: I think this falls into the category of the only way to know for sure is to take copious amounts of data from the driver and the car and see if you like it. If you're doing it on your car, I would think a progressive stop on the rear with a softer rear spring could ease the torque hit coming out of corners and make it a little easier to drive
07-20-2017, 10:02 AM | #11 | |
98
Rep 149
I think the prevailing perceived utility of bumpstops is to prevent smashing struts/dampers to the chassis or bottoming out. Bumpstops are worth so much more than that (to which you've indicated).
