07-13-2017, 03:37 PM | #1 |
17
Rep 54
Noob tire purchase for 2015 M4
Hey sorry if this topic is overdone but I couldn't find a thread that answered the question I'm looking for.
My 2015 M4 is in for service, and while there they noticed the outside edges of the front tires (255/35ZR19) are pretty worn (they are a bit worn). The rest of the tire has tread past the wear bar. They quoted me $715 for the two tires installed/mounted/balanced. Tirerack (via Big O) looks to be about $560 or so. Also the dealer is recommending an alignment for $300. So all told basically $1,014.45 for two tires from the dealer. Is there any benefit to going with dealer tires? What do you experienced people do? This is my first M car. Thanks |
07-13-2017, 03:51 PM | #2 |
135
Rep 408
Don't waste your time with the dealer. Tire Rack is fine. You dont need an alignment with new tires unless you're experiencing uneven wear and suspect its out of whack. How many miles on this set?
07-13-2017, 03:54 PM | #3 | |
17
Rep 54
And from what I can see wear is even. As in each tire is worn in the same way - nothing crazy going on. |
07-13-2017, 03:57 PM | #4 |
10785
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Just make sure that when you get the Tire Rack tires, they are the BMW STAR tires which are made specifically for BMWs.
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
07-13-2017, 04:14 PM | #5 | |
17
Rep 54
But thanks for the tip, I'll keep an eye out! |
07-13-2017, 05:36 PM | #6 |
734
Rep 4,635
Never ever buy tires from a dealer
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
07-13-2017, 06:10 PM | #7 |
82
Rep 283
My front tires have the same wearing out issue on the 255 35 19 MPSS front tires, seems common for the outside to wear out, really soft. I have heard some add extra few psi to compensate although never tried, mine are at 23k and need to be replaced. I actually have them waiting for me at tire shop, went with the M0 265 35 19 and already have the star 295 35 19 for rear.
Im paying about $700 for the fronts. $319 each |
07-14-2017, 08:04 AM | #8 | |
1104
Rep 1,083
BMW and Michelin will never share the differences between STAR and non-STAR tires, so don't bother asking. It's genius if you think about it, it forces dealers (or you) to buy new tires on CPO even the car's tires are brand new and creates more revenue for the dealers + tire companies. OP, looks like the last owner tracked the car. Without proper camber on the track, the outer sidewall will wear like crazy. It's worth going to an Indi performance/race shop to check the alignment and only pay for the work if it's needed.
Jimmy | BMW Addict | Signature Performance Wheels | OBSESSED WITH PERFECTION | IG: Signature_BMW | Email: jimmy@signaturewheel.com
07-20-2017, 12:15 PM | #9 |
Estorilblau Member
27
Rep 252
Definitely do an alignment check to see if there are any issues. Uneven tire wear may be an issue of bad alignment, be it toe angles or otherwise. If you have an alignment issue and don't get it fixed, you're just going to ruin another set of tires unnecessarily.
