07-05-2017, 12:16 PM | #1 |
1889
Rep 5,506
255/40R18 for front on OEM M219s
Has anyone run 255/40 on the OEM 18" wheels in front? I want to get more front end grip as I've noticed on track and autocross that the front tires give up before the rear in most situations.
The 255/40 is slightly taller than stock. According to the tire comparison sites about 0.25 inch bigger in diameter. Pricing is similar to the 245/40... has anyone run this config on a lowered car with no rubbing under cornering on track?
Auto Detailing Enthusiast!
07-20-2017, 11:48 PM | #2 |
El Eme Tres!
25
Rep 287
Running this size and no issues on Swift lowering springs. I do have around 2degreees of negative camber. On stock suspension no problems at all. Tires is RE-71R
Zero Ocho BMW Eme Tres
10-17-2017, 02:00 PM | #4 | |
355
Rep 1,192
10-17-2017, 02:13 PM | #5 |
winner of many hpde trophies
47
Rep 120
If you've already noticed the lack of front-end grip on 245s, you're not going to be happy with the balance of 255s either. Either find a set of rear 18x9.5 wheels to run up front, get an aftermarket set of wheels, or prepare for disappointment.
Even on 275 square on a 9.5" or 10" front wheel you're still going to want more front end grip for autox on a stock suspension. Trying to make due with the 18x8.5" up front is just wasting time and money. |
