Coby Wheel
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      06-16-2017, 07:17 AM   #1
jinsii
France
13
Drives: M4
Clicking noise coming from front wheel
Hello,
I own since May 2017, a m4 lci F82 CP may 2017, I have observed at low speed when I turn the wheels, or on winding road a metallic noise.
This véhicule have 2700 kms.
Do you have the problem?
Thks
Best
      06-16-2017, 07:42 AM   #2
GOLFFRR
GOLFFRR's Avatar
10817
Drives: GOLFFRR cart
take it to your dealer and have them take a look
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
      06-16-2017, 04:11 PM   #3
ferrarif1
320
Drives: F85, G05, E46M3
Have your dealer apply PUMA solution 62105224 which adds a small disc (part 31108053073) between the front hub and disc.
      06-16-2017, 04:52 PM   #4
Stealthm4bcm
53
Drives: M4 ZCP
Sounds like a rock is stuck in your heat shield. This is a common problem. Extensive threads on this issue. You can push them back with your hand. The heat shield is the aluminum cover in your wheel.
      06-17-2017, 04:01 PM   #5
dzu
119
Drives: BMW M4 F82 Austin Gelb DCT
Originally Posted by jinsii View Post
Hello,
Thks
Best
Do you have carbon ceramic brakes?
      06-19-2017, 02:34 AM   #6
jinsii
France
13
Drives: M4
No breakes ceramic, I say that I have this on the front discs
      06-20-2017, 06:34 PM   #7
LimiTed
57
Drives: Slow
I had clicking from my driver front wheel when driving straight. It was similar to the sound of a nail in a tire. The dealer added a felt disk/spacer and it went away.
I am now getting a much quieter clicking when I turn at low speed. Its been there for a while and I've tracked the car without issues. Not too worried about it. I'll have them check it out next month when I get my car serviced.
      06-20-2017, 08:26 PM   #8
paliknight
fuck this field
paliknight's Avatar
2192
Drives: 18 F80 CS/18 F80 ZCP/19 M2C
I have that same noise at low speeds. Especially when I turn in reverse. It's not the rock stuck in great shield noise. This one sounds like 3 clanks. Haven't taken it to the dealer yet.
      06-20-2017, 08:29 PM   #9
domino_z
1250
Drives: F-Pace SVR
had same issue from day i picked it up
turned out be front top mounts - replaced under warranty and all sorted
      06-20-2017, 08:30 PM   #10
MrSmileyDC
327
Drives: 2016 F82 M4
2016 BMW F82  [0.00]
Probably build up on the brake wear sensor. Try to not be so light on the brake pedal and actually get on them pretty hard from time to time. This seems to always solve my problem any time my the brakes start to squeal.
2007 e92 335i 6MT | Cobb AP Stage 1+ | ETS FMIC | AFE Dual Cone Intake (Sold)
ED 8/18 - PCD 10/19 | 2016 F82 M4 6MT | Alpine White | CF Roof | CF Trim | Black Extended Leather | Executive Package | Lighting Package | Adaptive M Suspension | 19" 437M Black Wheels
      06-22-2017, 09:22 PM   #11
Canuckles
Canuckles's Avatar
115
Drives: MW 2016 F82 M4
Just started having this issue as well, thnx for posting info. Gives me a decent starting point to diagnose issues.
      06-23-2017, 02:00 AM   #12
domino_z
1250
Drives: F-Pace SVR
easiest way to test if it's top mounts, turn car off, have someone turn the steering wheel while you rest your palm on top mount with hood pop'd - you'll feel it click through your hand
      06-23-2017, 02:41 AM   #13
dkhm3
dkhm3's Avatar
1882
Drives: 991.2 GT3 2020 X3MC
wheel bearing issue sounds like. go to the x5m boards. there's a ton of that on that car.
does it sound like this:
0:42 second mark
Currently:
2018 GT3 2020 X3MC
Previously:
1999 M3 2002 M3 2005 S4 2008 C63 2015 M3 2016 X5M 2019 911S
      06-24-2017, 12:07 PM   #14
F80_patrickmurray
F80_patrickmurray's Avatar
191
Drives: F80 M3
0:42 second mark
Mine sounds like this and I only have 1500 miles on the car
      06-24-2017, 01:36 PM   #15
dkhm3
dkhm3's Avatar
1882
if it bothers u, go to the dealer they will install a friction plate which will remedy it for a bit.
personally, i don't care and have driven with it for 10k miles on my x5m.
Currently:
2018 GT3 2020 X3MC
Previously:
      06-26-2017, 03:01 PM   #16
Canuckles
Canuckles's Avatar
115
0:42 second mark
That's exactly what my vehicle sounds like as well.
Nov. 15 Build, purchased new in March 2016. Currently have 21,000+ KMs on my car.
      07-10-2017, 02:37 AM   #17
jinsii
France
13
Drives: M4
Hello,
After depositing my vehicle at my dealership, there is indeed a note from BMW which recommends the placement of a washer ... I will be more tomorrow.
terahertz162.50
      07-11-2017, 08:56 AM   #18
jinsii
France
13
Drives: M4
Small return, although the modification is made, the hard noise
      07-13-2017, 01:02 PM   #19
bimmerfreak2k
Netherlands
Drives: BMW F80
Mine car sometimes also make the same noise. Did the dealer fixed this problem?
      07-14-2017, 04:12 AM   #20
jinsii
France
13
Drives: M4
Hello,
Unfortunately, the incident is still open to BMW, the dealership waits for action, I noticed that by washing the vehicle the noise disappears a while ... back I will inform you.
Best regards.
Jinsii
      07-14-2017, 05:21 AM   #21
MrSmileyDC
327
Drives: 2016 F82 M4
2016 BMW F82  [0.00]
It's brake dust building up on the brake pad wear sensor causing it to stick and drag on the rotor slightly. There is one on the front and one an the back. Your system likely isn't broken in enough based on your km. This happened on my previous e92.
https://www.bimmerfest.com/forums/at...1&d=1271809158
      07-22-2017, 04:55 AM   #22
jinsii
France
13
Drives: M4
i post my problem at this adresse
f80post
