06-14-2017, 01:46 AM | #1 |
Bored at work....
891
Rep 5,393
GTS and autocross
I know our cars weren't developed for auto-x, but beggars can't be choosers...
I'm at track setting and running 10 mm spacers on the stock tires. What should I set my front lip and rear aero to? Primarily low speeds (may hit 100kph for a spilt second). I'm currently at 3/8 out on the lip and middle setting on the lip. Just curious.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
06-14-2017, 02:31 AM | #2 |
557
Rep 762
If you got time and that spirit you could test a few different. Other then that, the more front splitter Is pulled out the rear angle should follow to also bigger angle.
I would not bother anything but max aero front and rear. Anyway, at these kind of events the one who bother heat up tire to propper pressure/temp prior to the accually run will win anyway:-) If its only single runs. Have fun and god luck👍🏻 ( also see the BMW M trackbook that come with car, they cover aero In It ) Last edited by Captain Unknown GT4; 06-14-2017 at 04:36 AM.. |
schnell325891.00 |
06-14-2017, 03:45 AM | #3 | |
Bored at work....
891
Rep 5,393
07-02-2017, 07:09 PM | #4 |
508
Rep 929
Personally, I don't see how max aero would help at an autox, the speeds aren't that high, and with the front lip hanging out I think it would increase the chances of nipping a cone. Most of my autoxing was done with my 95 M3 and it was a rare day to get out of 2nd gear, the way these things are geared you can probably run most courses in 1st. Just sayin.
07-02-2017, 08:32 PM | #5 |
General
21121
Rep 20,741
Drives: 2021 911 turbo
At relatively low autocross speeds, aero will not make a big difference. However, if you have the time to do so, I would still put it to the max setting. Every bit helps
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
07-02-2017, 08:46 PM | #6 | |
10785
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
07-02-2017, 11:45 PM | #7 |
2148
Rep 10,176
I'd use the front lip in cow catcher mode to deflect cones that you will hit. Also, put from tape on the leading edge. If you don't snag a few cones, you're not pushing it.
07-04-2017, 06:48 AM | #8 | |
Libertarian
71937
Rep 4,035
07-04-2017, 10:51 AM | #9 |
271
Rep 476
Max aero and painters tape over all the CF edges. Also, if you are serious about the auto x time - you could look into an auto x alignment. There are toe out settings that will help rotate your car faster around the cones.
