R44 Performance
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      06-12-2017, 02:49 PM   #1
theriz
406
Drives: 2017 M3
2017 F80 M3  [0.00]
2011 335i M-Sport  [4.00]
2015 M3  [0.00]
2009 X5  [10.00]
Another.... will these fit.
I need help of the wheel and tire gods of bimmerpost!!! This will be a daily driver/street use only.
I have a set of AG wheels on order.
Sizes: 19x10 ET 25
19x11 ET 35
I plan on running Toyo R888R's
Sizes: 265/30z/R19
295/30z/R19
Suspension will be KWv3's or KW Clubsports depending on how tight the fitment is.
Do you guys think that I will rub on KWV3's? Should I just opt for Clubsports since they have camber plates?
Any input or advice is much appreciated.
TIA.
2017 F80 YMB, ZCP, ZEC, ZLP, DCT. Production Date: 7/15/16
      06-12-2017, 04:07 PM   #2
CPWINCH
CPWINCH's Avatar
734
Drives: Toyota Prius
I cannot say for sure, but that wheel set up seems pretty good
What I can say for sure is opt for the clubsports. The camber adjustability is worth it on its own. If you run 2.5 degrees of camber or so it really makes the front end more responsive and have a lot of grip.
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
      06-12-2017, 09:14 PM   #3
mtr3s
177
Drives: M4 Comp
Yes they will fit. Most likely you will rub.
19x10 + 25 = 19x9 +13 = stock wheel + 16 mm spacer.
19x11 + 35 = 19x10 + 23 = stock wheel + 17 mm spacer.
      06-18-2017, 08:23 PM   #4
chrisx_xzb
chrisx_xzb's Avatar
23
Drives: Sliverstone F82 M4
On R888 yes! On PSS/PS4S/P0 probably no. My rear is a bit more aggressive and running 285 30 20 P0, no rub
theriz405.50
f80post
