06-09-2017, 04:30 PM | #1 |
Assistant to the Regional Manager
27
Rep 149
Largest Spacer with 18x10 et25?
running 275/35 NT01s, square. Just curious what the largest spacer you can run front/rear would be?
I have 12mm spacers I use with my daily set which are just a bit too big. I'm guessing answer is either 10 or 8mm. Basically don't want to swap off spacers every track day... I'm on Ohlins R/T (mid setting, -20mm) and -3.0 camber in front thanks!
'08 E92 M3 DCT, AW on Fox Red
06-09-2017, 06:32 PM | #3 |
2739
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
8mm is not possible unless you are ok with no hub contact (not a good idea). 5mm works. 10mm is possible with your camber setting.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
06-17-2017, 06:55 PM | #5 | |
27
Rep 149
That's amazing fitment up front, did you remove your fender liners? I rubbed a few small portions off running the 12mm with same wheels and 275/35 NT01s. A little more camber might do the trick for me
06-18-2017, 02:16 AM | #6 | ||
721
Rep 2,342
Just running lots of camber. 30 profile helps |
06-19-2017, 02:35 PM | #8 |
IG: @dj_dub
1803
Rep 1,452
Drives: 2010 BMW E90 M3 - SG/FR 6MT
I've run 10mm in the fronts and 12mm in the rears without any issues. I personally feel that's the limit with my setup.
Purple Turn 2 (1st Session) OrangeACS_0138_Aug1416_by_Keeg-CaliPhoto by dj_dub, on Flickr Purple Turn 13 (3rd Session) ACS_3943_Aug1416_by_Keegan-CaliPhoto by dj_dub, on Flickr
CarboProject CF Plenum | Dinan CF Intake | ESS Tune | RKP X-Pipe | Akra w/CF Tips | MFactory CF DS | CSF Cooling | AST 5200 | Hotchkis F/R Sways | SPL/Ground Control/Fall-Line Arms | DEFIV Diff Brace | StudioRSR Rollcage | 3-piece BBS RT88 | Michelin PS4S | Brembos F/R | Recaro Profi SPG XL | CAE Ultra Shifter | Perf Elec Wheel V2 | BAVSOUND | GT4 CF Front Lip/Canards/Rear Wing | Arkym CF Rear Diffuser | Forcewerkz CF SS | Varis CF Lower Tray | Turner Skidplate | BayOptiks Headlights
redpriest2147.00 |
06-20-2017, 11:53 AM | #9 |
27
Rep 149
dj_dub Looks great! Which 10mm spacer are you running? I just called TMS and they couldn't tell me if the 10mm is safe to run based on the hub size and wheel backspacing
06-21-2017, 03:32 PM | #10 |
IG: @dj_dub
1803
Rep 1,452
Thank you! ...I'm using ECS Tuning 10mm spacers. No problems whatsoever.
