06-01-2017, 06:42 AM | #1 |
104
Rep 218
Track tire wear without camber plates?
I've read through some of the threads on camber plates and was set on getting them along with some other suspension mods before I go back on the track, but the person I spoke to at the shop had never added camber plates to an F80 before and sounded hesitant.
With stock tires and suspension, I made it through two track days. With that said, I plan on getting either some NT01's or R888's, but my question is how many track days can you get out of the tires without camber plates versus having camber plates and running at a negative camber? Is there a huge difference. Thanks, Thomas |
06-08-2017, 01:25 AM | #2 |
210
Rep 400
Why...
Why new tires already? Why r-comps immediately? Why use a clearly compromised street focused alignment at the track? If you're going to drop over a grand on tires, do yourself a favor and get an appropriate alignment to keep them wearing evenly and providing you with the peak traction you've paid for. Camber plates are cheap, easy to install, and make a massive difference. |
06-08-2017, 08:34 AM | #3 | |
104
Rep 218
06-08-2017, 08:53 AM | #4 | |
1104
Rep 1,083
Jimmy | BMW Addict | Signature Performance Wheels | OBSESSED WITH PERFECTION | IG: Signature_BMW | Email: jimmy@signaturewheel.com
06-15-2017, 10:50 AM | #5 |
226
Rep 482
Honestly the plates are not really necessary if you are running something like an NT01 at the track. I beat the hell out of them without plates and they wear fine. I think this has been extremely over-exaggerated by people that don't actually track the car. And yes, I am out 5-8 times per year.
06-15-2017, 12:13 PM | #6 | |
General
21117
Rep 20,741
Drives: 2021 911 turbo
I'm out about 18~20 days per season. During the 2015 season, I had no camber plates on the car because none were available at the time. I was burning though my square NT01s in 4~5 track days with rotation between the corners and even flipping them on the rims. Throwing away tires that were corded on the shoulders but still had plenty of tread left was quite frustrating . Having now the camber plates and having moved to a staggered setup (which prevents front-to-rear tire rotation), I am now getting 8~10 days out of the tires. That is a big difference to the wallet. The camber plates paid for themselves after just one set of tires.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 06-18-2017 at 09:59 PM.. |
Sonic_M2c28.50 |
06-17-2017, 12:59 AM | #7 | |
43
Rep 147
2016 BMW M3
2014 Porsche Cayenne GTS Past: 2011 E90 M3 |
06-17-2017, 08:31 AM | #8 | |
135
Rep 408
I hope that helps. |
06-18-2017, 12:40 PM | #9 | ||
226
Rep 482
2nd, I think they will help some people sometimes. My car sits at at -2 on the front after my last plate-less alignment job. I have 6 days on my current 275/305 NT01 set, and there is a only slightly worse wear on the outside edges of the front tires. The variables of course, driver, and suspension setup will dictate if the plates are necessary for you or not. I run xtreme speed and speed ventures events in SoCal, I would say less than 1 in 3 of the F8xs are running plates (i usually say hi and talk shop with the other drivers). In any event if they help you go for it. My point stands that they absolute omfg you need camber plates to run at the track tagline is exaggerated. |
C-Mu135.00 |
06-18-2017, 04:16 PM | #10 | |
General
21117
Rep 20,741
And when I mention track rats, these are not the "occasional" trackers (i.e. Less than 6-8 days/year). I prefer keeping the car as stock as possible. I'd much rather focus on the "driver mod" to improve lap times. That is the whole point of me getting an ///M car to serve the dual purpose as a practical DD and track toy, it barely needs any mods to be track ready. Camber plates are not about lap times, but rather about reducing the cost of consumables; and all my ///M s since my E46 have needed camber plates to get decent track tire life.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 06-19-2017 at 11:57 AM.. |
06-18-2017, 04:41 PM | #11 | ||
2148
Rep 10,176
Even with street tires on the track, you'll get better turn in, less srubbing/understeer, better tire wear - WITH camber plates. I change my camber from street settings to track settings at the track. It takes about 10 minutes. I get great and predictable tire wear on both my street tires and my track setup... Strongly suggest not listening to slavearm. |
06-19-2017, 04:37 AM | #12 |
104
Rep 218
Thanks everyone for your input. There is a track in my back yard and I plan on using it every chance I get means I bought an HPDE insurance policy for a year and it's just outright addictive.
The shop did come back and say they can install the camber plates now, so I have my fingers crossed. All of my parts are on order now (Dinan tension strut ball kit, Dinan rear suspension link kit, Dinan adjustable anti-roll bar, M Performance HAS Coilovers) and that just leaves me needing to order the Ground Control camber plates today. |
06-19-2017, 10:26 AM | #13 | |
210
Rep 400
Like you, I'm also cognizant of message board 'group think' and empirically test changes myself before drawing conclusions and making recommendations. I ran 4 track days on the F80 without plates. Two on MPSS, Two on AD08R. Every session had dramatically uneven tire temps (using a pyrometer), as much as 60F higher on the outside shoulders with the MPSS. After installing plates to -2.5 and doing two more events it's much better, but next time the car is on the rack it's going to -2.8. Data is what will move the bar on this board - particularly within the track section. We should all try to back up our findings with some measurements as we look to optimize this chassis. We did it a lot on S2Ki and there's a handful of national champions on that board now. My setup: F -2.5, 0 Toe, 7.6 caster R -2, 3/32 toe JRZ RS Pro 550/800 @150psi cold loaded AD08R @ 35psi hot - Carcass temps (O->I) 180-170-160F +-10 Carbotech XP12/10 I run low 1:40s at Laguna and near sub 2 at T-Hill east for a sense of pace. |
06-19-2017, 04:46 PM | #14 | |
226
Rep 482
C-Mu135.00 |
06-19-2017, 09:50 PM | #15 | |
2148
Rep 10,176
If you don't have added negative camber and they are wearing evenly, you're babying the car. Rears take care of themselves. They wear evenly with stock camber, though I run -2 degrees for better cornering. |
06-21-2017, 05:59 PM | #16 |
General
21117
Rep 20,741
Just shows how our cars roll off the factory with alignments that are all over the place. Mine came with -2deg in the rear. I had it reduced to -1.6.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
larryn2147.50 |
