05-31-2017, 10:04 AM | #1 |
29
Rep 105
513M Wheels Max Tire Size *Pics* Square | Staggered
I've seen info scattered throughout the forums but nothing dedicated to the 513M (from searching) that lists actual tire sizes with helpful pictures.
It would be awesome if someone could post pictures of their OEM 513M set up with tire sizes. Square set up's welcome as I am thinking about 18x10 square for track use. I've read 285 | 35 | 18 is max for rear and 275 | 35 | 18 max for front? I'f anyone has 265 | 40 | 18 with 285 | 35 | 18 Also looking to see what 265 | 35 | 18 and 275 | 35 | 18 looks like Appreciate the help! |
05-31-2017, 04:01 PM | #3 |
29
Rep 105
I understand Tire Rack lists OEM Sizes but many people have pushed the limits on fitment with the 513M. I'd like to see who is...
Have you discovered additional insight by exploring Tire Rack outside of their OEM boundaries? |
06-01-2017, 07:34 AM | #4 |
69
Rep 193
285/30/18 Michelin Cup on square 10x18 513M wheels with 12 mm spacer up front.
streetmasters28.50 jww///9567.00 |
06-01-2017, 12:07 PM | #5 | |
256
Rep 928
Square setups are only good on the F8x for... rotating tires on the track for even wear they didn't suffer from understeer like he E46 for example. A better setup would be 275/35/18 and 305/35/18 on Apex wheels.
Gone but not forgotten:
2007 E63 M6 SMG, 1999 996 Carrera Cab AT, 2007 & 2008 E90 335xi AT, 2011 E93 M3 DCT, 2X 2002 E46 M3 SMG & 6MT, 2016 F80 M3 DCT |
streetmasters28.50 |
06-02-2017, 12:37 AM | #6 |
29
Rep 105
06-02-2017, 03:24 AM | #7 |
69
Rep 193
Absolutely no rubbing at all in any conditions. Suspension is stock. Bear in mind that the car sits about 15mm lower due to the smaller wheel diameter, but that doesn't really matter on the track.
06-02-2017, 06:26 PM | #8 |
29
Rep 105
Perfect. I'm not going to be running R Comps this year but definitely want to go square with some good contact. 285 is good for me!
