05-18-2017, 05:16 PM | #1 |
85
Rep 330
Square setup's effect on DSC
Hi,
I am considering getting a dual purpose square setup but I am wondering if it will negatively impacts DSC during daily drives when going through puddles or pouring rain? Thanks. |
05-18-2017, 06:22 PM | #3 |
1889
Rep 5,506
Power is only sent to the rear wheels on the M3... DSC only affects the drive wheels usually by cutting power or applying brakes to the rear.
Auto Detailing Enthusiast!
05-18-2017, 08:08 PM | #4 |
85
Rep 330
I thought it compares wheel speed between front and rear wheels and the square setup will confuse it by having an incorrect ratio when there is no slip.
05-19-2017, 12:55 PM | #6 |
85
Rep 330
05-19-2017, 02:20 PM | #7 |
2760
Rep 5,483
sensitive drivers will notice a square setup, or any setup that puts a smaller diameter than stock on the back than the car normally sees, will be a little more sensitive to wheelspin and cut in a bit earlier in some situations. In daily driving you'll never notice a difference IMO
it's looking at all 4 wheels plus the accelerometers, driver inputs etc. all the time, so changing one corner or one end of the car will change how it responds, in my experience OTherwise the system doesn't care. Remember one of the factory snow tire setups for these cars is a square setup. It's not like some companies' default tuning *cough* *ahem*GM*cough*hack* excuse me! that can sometimes freak out if you get the stagger a bit wrong
05-22-2017, 01:09 PM | #9 |
winner of many hpde trophies
47
Rep 120
When I went to 275/35/18 square, dsc was even MORE annoying. Any enthusiastic weight transfer in roundabouts, or even brisk accel over rough pavement was so stunted I have to drive with DSC off all the time now. Maybe with euro-mdm or tuning the thresholds could be corrected, but it was super-nanny mode stock and on squared it's unliveable.
Just condition yourself to flip off DSC when you get in and start up. The M3 isn't the car for someone afraid of a little casual rotation, anyways. |
05-22-2017, 01:29 PM | #10 |
2760
Rep 5,483
My "boring" toyota allows you to set cruise control with all the nannies off, wish that was possible on these
I have not noticed anything super-annoying from DSC except when I ran 285's up front and 275's in back in a failed attempt to kill my unkillable RS3's before I went back to a more streetable tire. Really cut in early with that setup. But then I almost always have my DSC off. Wore my DSC off button out, in fact, and had to replace it, which was the single most expensive unplanned failure on the car so far btw at $140. Nice that the car allows you to switch it off at any speed in any situation and it never comes back on until you turn the car off, not so nice that they failed to design for thousands of cycles, I probably use that button 6-7 times a day
05-22-2017, 01:31 PM | #11 | |
1889
Rep 5,506
As for running a different sized front, I very much doubt it makes a difference. DSC does not affect the front wheels. On track, I always use DSC off so it makes no difference there.
05-22-2017, 01:42 PM | #12 | |
2760
Rep 5,483
