05-15-2017, 04:33 PM | #1 |
Rep 43
Thoughts on TE37 Fitment
Hi all,
Looking to pick up a used set of TE37's with tires and want to know if this set will work on my car without any rubbing. It's a family car so safety 1st. Car is an e90 M3 with EDC on stock suspension. Here are the wheel specs: TE37RT Nitto NT05 tires 18 X 9.5 +22 (275/35/18) 18 X 11 +34 (295/35/18) Question is will it rub and any issues with EDC or ABS due to diameter differences? Thanks in advanced for your input! |
05-15-2017, 06:18 PM | #2 |
239
Rep 479
Do it... can never go wrong with TE37
I have TE37RT 10.5 et21 squared and no issues. [IMG]MSR cresson-23 by Chamba, on Flickr[/IMG] |
05-15-2017, 11:18 PM | #3 |
Rep 43
05-16-2017, 08:28 AM | #5 |
1616
Rep 1,588
They will fit fine, I run the same offset and tire up front with no issues and I am lowered a little bit. For the rear I would add a 5mm spacer and the car will sit perfect
2012 E92 M3
Instagram Turbo__Joe |
05-17-2017, 09:05 AM | #6 | |
Rep 43
Looking forward to getting them on the car this weekend! |
chamba002238.50 |
07-29-2017, 02:36 PM | #7 |
29
Rep 151
My new te37rt with 18 9.5 / et 22 and 18 10.5 et 20 265/35 285 35 pzero. Rubbed at front fender line.... rear most likely rub too, but not sure..
Damn I wish they had 27 rear ET and 28 or 31 front et (ppl can add spacers instead of having to machine it off).. The front rubs quite bad. |
07-29-2017, 06:34 PM | #8 | |
183
Rep 995
07-30-2017, 02:45 AM | #9 |
29
Rep 151
stock edc zcp. otherwise I wont complain much.
A shop says the shock absorber mountings may be bad causing the ride height to go slightly lower. Any logic to this? And this car have 4x shock mountings or 2x mountings? Last edited by Razif; 07-30-2017 at 02:52 AM.. |
08-02-2017, 03:44 PM | #10 | |
2739
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
08-03-2017, 01:50 PM | #11 |
Rep 43
Apologies for late update. So i purchased the wheels and the tires as per the specs stated in the thread and am happy to report they fit perfect with no rub even at full lock. Keep in mind mine is an e90 and I hear the sedan has more clearance in the rear that the coupe.
It also filled the gap nicely which is great as I have no plans to lower the car. The rears have maybe a half inch gap and fronts has just a tiny bit more. I added 10mm spacers on the rear but more for aesthetics, to have the rears stick out just slightly more than the fronts. Super happy with the wheels and the tires. Grip and unsprung weight have been drastically improved over stock 19's. Only thing i don't like is the hub rust |
11-08-2017, 05:20 PM | #15 |
93
Rep 1,089
Why do you say this? Experience or you have run this size? I'm going to run a 10.5 et34 with a 305 and shouldn't be an issue.
Per my measurements with my zcp 10 et 25 with 285 I have 1" inside so there is a ton of room. I'm guessing you're just opining without personal knowledge.
F80 M3 HRE FF04 275/305.
11-08-2017, 05:21 PM | #16 | |
93
Rep 1,089
Awesome! Post pics!
11-09-2017, 10:26 AM | #17 | |
2739
Rep 6,734
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 11-09-2017 at 01:13 PM.. |
11-11-2017, 07:46 PM | #18 | |
802
Rep 1,566
11-11-2017, 11:49 PM | #19 | |
93
Rep 1,089
Follow my measurements. You were .25 more in hence your contact. No wonder you got it wrong. Also with a 10.5 and et25 with 295 you only have .15" outside clearance. Your math is garbage. Op go in tire and wheel forum and search 305. It confirms my findings.
11-12-2017, 03:09 AM | #20 |
2739
Rep 6,734
What are you talking about? The OP was asking about an 11" et34 wheel. You asked me why I made my statement about the OP's 11" wheels. I responded with my reasons. None of my posts had anything to do with your 10.5" wheels.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 11-12-2017 at 04:01 AM.. |
11-12-2017, 03:11 AM | #21 |
2739
Rep 6,734
I would suggest et30 but it's going to be tight.
'23 X7
11-26-2017, 03:37 PM | #22 |
802
Rep 1,566
Noted, thanks. What offset would you recommend for 275/30 on a 19x9.5 front with OEM non-ZCP suspension and factory camber? I read in another thread you mentioned et22 would require a little extra camber so I was thinking et26...
