04-25-2017, 09:01 AM | #1 |
161
Rep 254
Soft tires that wont rock chip my paint to hell
I just sold my e92 and I ran Nitto NT01s on it and loved it. The bad thing is it would heat up and pick up rocks like crazy and later throw them against the paint.
I just got a new Ferrari Red F82 and really want to take care of the paint. I am buying new track wheels and tires and I am considering going with something less aggressive for this reason? Any thoughts on a different tire? Also the front of the car has clear bra on it. Anyone clear bra their rear bumper to protect the lip of the wheel well from rocks from the rear tires etc? |
04-25-2017, 09:07 AM | #2 | |
636
Rep 3,039
ccondo160.50 |
04-25-2017, 11:51 AM | #3 | |
636
Rep 3,039
Foot Note:The clear bra will get "chipped" as well. So your car will never look as if you just drove it off the lot when looking at any lower body panel at 6 inches away. |
04-25-2017, 12:00 PM | #4 |
The limit of adhesion is my home.
1702
Rep 3,778
get the M-Side Skirts. I have them and have ZERO paint chips or rock impacts on the side panels of my car.
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
04-25-2017, 12:57 PM | #5 |
636
Rep 3,039
04-26-2017, 09:32 AM | #7 | |
1163
Rep 2,561
What's your priority? a P.S.: Yes, you can clear bra the entire car ($3-5K), and it will get damaged first, instead of the paint. But it will get damaged by debris nonetheless, and the damage will be visible.
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
04-26-2017, 09:48 AM | #8 |
271
Rep 476
04-26-2017, 09:51 AM | #9 |
271
Rep 476
I found that the Conti DWS 06 that i used for winter hardly picked up rocks/stones. I never heard anything kicking up into the wheel wells with these tires. Also, you will never notice any performance difference during street driving and i felt that they actually hooked up better at launch than PSS.
04-26-2017, 11:57 AM | #10 | |
636
Rep 3,039
05-10-2017, 07:53 PM | #13 | |
1163
Rep 2,561
Though, personally, I would rather live with a few paint chips...
'19 TM3P (BK/BK)
05-10-2017, 08:04 PM | #14 |
50
Rep 72
The most important two areas to protect are 1) the quarter dogleg... needs film 4" higher than what the factory provides and 2) the rear bumper where it follows the contour of the rear wheel along with the very bottom surface. Finally, that black rocker tape should finish you off nicely! You need soft tires...not having traction is pointless.
05-10-2017, 09:53 PM | #15 |
161
Rep 254
I bit the bullet and went with nitto nt01s.
I am having some additional xpel added, and I bought some track tape that I will put on before going to the track. |
05-12-2017, 07:46 PM | #16 |
614
Rep 1,133
The oem bmw star rated MPSS are notorious for slinging rocks against the car. I did clear bra on my rockers, lower doors and the full rear wheel arch. I ended up going aftermarket on wheels that are wide and are offset to make them flush with the fenders. Went with the MP4S. They're better than the MPSS as far as road noise, wet and dry traction. As a bonus, they don't sling the loose small gravel on the roads. It's nice to be able to drive down the road and not cringe listening to all the rocks getting kicked up.
It's good to be bad
ccondo160.50 |
05-13-2017, 10:51 PM | #17 |
1326
Rep 1,481
A delta of 1 inch in ride height hardly makes any difference.. the compound of the tire makes a much bigger difference and unfortunately that is the trade off. My RE71Rs especially when new, felt like post it notes and picked up everything it rolled over. After that initial layer wore off it was a lot better, but nothing like tires in the ultra high performance category or lower.
