BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      04-08-2017, 11:20 PM   #1
0_to_60
0_to_60's Avatar
81
Drives: E92 M3
Thinking of running PSS 295/30/19 on 220s
I need two rear tires, have a cheap rear 295s to use. Currently running 275/35/19 on the stock 220s. I know i need at least a 10'' wheel. Do you guys think i would run into any other issues? Like during high speeds, or normal driving
Also does anyone have any pictures of this setup?
      04-10-2017, 05:46 PM   #2
0_to_60
0_to_60's Avatar
81
Drives: E92 M3
anyone have any links to this topic?
      04-10-2017, 11:51 PM   #3
///MPower15
///MPower15's Avatar
501
Drives: 2011 E92 M3
I know some people run 295/30 on 359m, which are also 10". I think it is still in the safe zone for 10" wheels so it shouldn't really cause any major issues.
      04-10-2017, 11:52 PM   #4
0_to_60
0_to_60's Avatar
81
Drives: E92 M3
the problem is the stock 220s are 9.5 in the back
      04-11-2017, 12:46 AM   #5
///MPower15
501
Drives: 2011 E92 M3
I would not put 295 on a 9.5" wheel.
0_to_6081.00
      04-11-2017, 10:36 AM   #6
dparm
Stop the hate, get a V8
dparm's Avatar
3850
Drives: C7 Corvette GS, AMG C63 S
295 on a 9.5" wheel is a bad idea. Even if the shop can mount it, you will not get the right contact patch which leads to bad handling and incorrect wear. It's a safety issue.
If you want the "wide tire" look, get wider wheels -- simple as that.
Past: 2011.5 M3 sedan ZCP
0_to_6081.00
      04-12-2017, 03:01 AM   #7
becausephilchow
175
Drives: 08 E90 M3
I wouldn't even put the 295/30/19 on 19x10 in all honesty.
      04-18-2017, 08:06 PM   #8
PetrolFumes
351
Drives: Raptor, GT3RS,E92 M3,X5M50i
I'm about to throw 285s on the rear with my zcp wheels to handle the extra power of the blower. Anyone have any experience doing this? I know 295 is a bit much as mentioned above.
      04-19-2017, 04:03 PM   #9
ApexWheels
BimmerPost Supporting Vendor
ApexWheels's Avatar
1428
Drives: M3
If sidewall support and handling is important to you, the OEM 220's should be limited to 275/35-19 tires. For OEM 359's I wouldn't go any wider then the GTS size of 285/30-19.
295/30-19's really deserve 10.5" (or 11") wheels for proper sidewall support.
- Ryan
m3post
