04-07-2017, 12:22 PM | #1 |
26
Rep 33
M4 ZCP front tire replacing specs
Hi guys, I'm thinking about getting a new set of front tire for my M4 ZCP with 20 inch wheel. Do you think a 265/35ZR20 tire could fit the wheel? The OEM spec is 265/30ZR20. Thanks!
04-07-2017, 12:58 PM | #2 |
945
Rep 751
Since both tires are same width and both are 20" it should fit the same wheel. However your new 35 aspect ratio are taller than OEM thus if you put it on the front, then the front will sit higher than the back. Not good.
04-07-2017, 05:48 PM | #3 |
Recovering Mazda Addict
19
Rep 127
Even if it fits, it'll mess up the TC programming as the OD difference between front and rear will be a lot farther off. Expect a lot more intervention from TC.
04-08-2017, 06:00 AM | #4 |
General
21117
Rep 20,741
Drives: 2021 911 turbo
I would not recommend this. Too many "wrongs".
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
