04-03-2017, 11:25 AM | #1 |
549
Rep 944
F80 same offsets as F82
just picked up a F83 but currently also have a highly modified X5M and just traded in a w212 E63.
never been on a forum so active and some many post about the same thing. I cant seem to figure out if offsets are the same on a F80 compared to a F82/83. looking to purchase a used set of wheels and seeing more f80 wheels. Seeing a lot of variance on widths and ET depending on lowering method. I will most likely use KW HAS and heard the widest front is 9.5. So question is do f80 wheels fit on a f83/82 |
04-03-2017, 11:34 AM | #2 | |
6580
Rep 5,304
If you want a nice flushed look, the safest wheel width/offset for almost all suspension/tire set ups start at around: Front 9.5" ET20. Rear 11" ET40. You can go more or less aggressive depending on your suspension and tire set up. Keep in mind that even this set up won't accommodate snow chains (in case you were wondering). That being said, the F80 and F82/F83 do indeed accommodate different offsets on the rear when you really push the "fitment" to "maximum flush" (all other things like camber and suspension being equal). The M3 is wider edge to edge but the M4 might have deeper wheel wells (not sure about this). Last edited by x.shell; 04-03-2017 at 11:40 AM.. |
04-03-2017, 03:57 PM | #3 |
///Multiple
2992
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
To answer this question, and if you're talking about OEM wheels, yes, the F80/F82/F83 all share the same OEM 18" and 19" wheels with the same offsets. Also the F80 and F82 CP share the same wheels and offsets.
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
04-03-2017, 06:45 PM | #4 |
General
21117
Rep 20,741
Drives: 2021 911 turbo
You can also add the F87 to that list
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
SD ///M42992.00 |
