XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      04-02-2017, 04:27 AM   #1
shtaka
Drives: 2015 X1
Automatic door unlock
Is there a setting somewhere that will unlock all doors when the key comes out of the ignition?
      04-02-2017, 09:02 AM   #2
vstolpner
25
Drives: 2019 F39 X2 m35i
Yes, that's based on the setting to unlock one or all doors when the key on the button is pressed.
So if pressing the button on the key only opens the one door, then taking the key out of the ignition will only unlock one door as well.
      04-02-2017, 01:46 PM   #3
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
It can be done via coding only.
      04-02-2017, 03:12 PM   #4
vstolpner
25
If I'm not mistaken it's an option via iDrive menu.
Edit: the option to unlock all doors or one when unlock button is pressed... If your door currently opens when you eject the key and you have iDrive then no coding necessary. Otherwise coding is needed
      04-06-2017, 02:29 AM   #5
MajorTranq
Drives: X1 35i
There's an iDrive setting to unlock all doors when engine is switched off. Doesn't work for me, though. According to the manual it should work. Made sure the child safety locks were disabled. Fussed with it with a buddy on a recent road trip where we frequently needed to access cargo in the rear. Try as we might, only the front doors would unlock. Read on another forum that a guy coded his doors to unlock but it wouldn't work unless he long-pressed the start/stop button to turn the car off. Didn't work for me, so I believe the "unlock all" function must be coded despite what the manual says. No biggie. Just irritating. I enjoy the comfort access until I need to open the rear doors, in which case I need to hit the unlock button on the dash, dig for my keys, or touch the driver door handle twice.
      04-06-2017, 08:36 AM   #6
d1saster
Bulgaria
60
I have CA and my setup is like this: all doors doors lock as soon as the car starts moving (2 mph) and unlock automatically when i hit the start/stop button without holding it. I coded it myself using bmw coding tools. Let me know if somebody needs all codes associated.
      04-06-2017, 10:32 AM   #7
jinda
jinda's Avatar
17
Drives: 2013 X1 xDrive35i M Sport
I have CA and had to code it using iCarly to unlock all when I long press on the start/stop button.
I don't see any option on the iDrive on my car except for the unlock button on top of the radio.
2013 X1 x35i M Sport
Past: 2011 Mazda CX7 AWD Sport | 2004 BMW 330i ZSP/ZPP | 2008 Hummer H3 | 2005 Honda Civic VTi | 1997 Honda Civic ESi | 1996 Nissan Sentra SS EXi
      04-06-2017, 02:50 PM   #8
d1saster
Bulgaria
60
Look for option to eject the key as soon as you press srat/stop button. This will give you immediate unlock without holding the button pressed.
      04-07-2017, 12:46 PM   #9
D Unit
93
Drives: 2013 x1 s28i
I have icarly but can't figure out how to code it. Initially, I had someone code my car with this feature (ignition turn off --> automatically unlock all doors), but when I was playing with icarly, I must've disabled the feature. Now, I can't figure out what exactly I'm supposed to code again?! Help.
D Unit
Bay Area, CA
      04-08-2017, 01:15 AM   #10
andybmr
Drives: 2015 x1 xdrive 28i
I did mine with just adjuster controller on left side you can unlock one or all four doors and i don't have i drive
      04-13-2017, 12:01 AM   #11
d1saster
Bulgaria
60
To enable auto unlock when engine is turned off code the following options in CAS module:
ER_KEYOUT_AUTOVR
Aktiv
Unlocks all doors when you remove key
KOMFORT_EJECT
Aktiv
AUTOMATICALLY EJECT KEY AFTER SWITCHING OFF IGNITION OR ACCESSORIES BY HOLDING START/STOP BUTTON (LINKED TO [KOMFORT_AUS_IN_50MS])
KOMFORT_AUS_IN_50MS
wert_05
TIME TO HOLD START/STOP BUTTON FOR AUTOMATICALLY EJECTING KEY [TIME_MS=DATA*50] (LINKED TO [KOMFORT_EJECT]) wert_03; wert_05 (instant), wert_02 (0.50s), wert_04 (0.60s), wert_07 (0.70s), wert_01 (2.00s) OE=15*50=750ms
