03-31-2017, 08:53 PM | #1 |
Sunburned
238
Rep 1,097
Drives: '16 F83 M4 Convertible 6MT
Need help with 20" tire sizes
Whatsup guys.
Just picked up a set of BC Forged RS41 20x9.5 +20; 20x11 +40 I'm in NYC so roads are shitty. I want to put the most meat I can on the fronts, so did some math and 255/35/20 F and 295/30/20 R are almost exactly the same OD. I know most ppl go with 265/30 295/30 but that's 10mm less sidewall upfront. Anyone know if ill be good with the 255/35 295/30 setup? Thanks
2016 M4 Convertible 6MT - SO/SO
2013 535i 6MT MSport - Retired 2011 Z4 SDrive35i 6MT- Retired |
04-03-2017, 12:34 PM | #3 |
230
Rep 1,556
I'm running 275/30 up front and it is very close to the rear diameter of 295/30. At like 1.x%. No rubbing either with same size and spec wheel as yours plus I am lowered 1" in front.
04-04-2017, 11:31 PM | #4 | |
Sunburned
238
Rep 1,097
I have the HAS kit i just havent installed it yet, wouldnt be slamming it either, just bring it down to top of the tire. Your OD is 26.5", mine would be 27.03"
04-05-2017, 11:41 PM | #5 |
1249
Rep 1,973
i would love to run a 35 series front tyre on my zcp for exact reasons you point out
ideally i'd like to run the same tyre setup as the m5 - 265/35/20 and 295/30/20 as they use same size rim as zcp however looking at how close the front sidewall comes to the inner fender liner on lock, i just don't think the taller OD of even a 255/35/20 (27") vs oe zcp 265/30/20 (26.3") will fit Last edited by domino_z; 04-05-2017 at 11:48 PM.. |
04-09-2017, 06:53 PM | #6 |
Lost Motorcyclist
167
Rep 379
Hi there,
I just picked up a 2yr old M4 and it has Koya 20 inch rims fitted, the front tyre is a 255/35 and has little to no issues with rubbing. Car also has KW height adjustable springs and has been lowered about 15mm at the front. Cheers, |
04-09-2017, 07:41 PM | #7 |
Sunburned
238
Rep 1,097
Thanks. Glad to here cause I just got a set in that size delivered yesterday lol
