03-30-2017, 11:49 AM | #1 |
162
Rep 460
Non-Runflat Tires
I was wondering if anyone has advice on running non-runflat tires? An extra wheel and tire would just give the car more weight and less cargo room to purchase an extra set. How about a can of fix-a-flat or something, do those work and what happens if you have a blowout instead of a small leak?
03-30-2017, 11:58 AM | #2 |
General
21117
Rep 20,741
Drives: 2021 911 turbo
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
03-30-2017, 01:20 PM | #4 |
General
21117
Rep 20,741
There is what is called the ///M mobility system in your trunk, in the compartment below the trunk floor. This kit is composed of an air pump and a sealant can so you can fix and inflate a flat tire. Sort of ///M's own fix-a-flat kit. That's why I said RTFM
03-30-2017, 02:13 PM | #5 | |
105
Rep 236
I don't worry about performance in DD and it's a safer choice if I want to have a long trip for few days. 20" tire has very low profile and get flat very easily. |
03-30-2017, 02:48 PM | #6 |
///Multiple
2992
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
AAA Premier
You realize that you also get 3 or 4 years (depending on model year) of BMW Roadside Assistance as part of BMW Assist, right?
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
03-30-2017, 03:09 PM | #7 |
614
Rep 1,133
This is a easy solution that works. I've used this several times already. No messy sealants, crappy run flats or a trunk full of tire. Just plug and air up. I have the Dynaplug Pro in both of our cars.
http://www.dynaplug.com
It's good to be bad
hlothery481.50 |
03-30-2017, 04:15 PM | #8 |
162
Rep 460
That is what I was talking about, different solutions that I didn't even know existed. I might go with the Dynaplug. That is incredible.
So I guess the only problem to a sidewall damage will be towing? Pretty sure there is no "fix a flat if the sidewall get a puncture. |
03-30-2017, 04:51 PM | #9 | |
General
21117
Rep 20,741
I tried it once on my E46 way back. Could never get the wheel to inflate and ended-up calling (free) BMW roadside assistance. The dealer charged me over an hour to un-mount the tire and degunk the wheel and tire before fixing it. So a puncture that could have been fixed with a $15 plug ended up costing me a couple of hundreds So now, when I get a new car, the first thing I do is rip that useless ///M mobility kit out of the trunk and store it my basement until I sell the car. Weight savings . And if ever I get a flat, I'll just directly call BMW roadside assistance and get the car towed to the dealer .
03-31-2017, 07:26 AM | #10 | |
Seeking mental floss
482
Rep 806
skalberti614.00 |
03-31-2017, 09:02 AM | #11 | ||
162
Rep 460
After re-reading the comment above, I did read the manual F.Y.I. to the emojicon poster above. I meant something more reliable than the fix a flat that comes with the car. Thank you everyone for suggestions. I am glad I asked as I will swap out the tires because I do occasional track days. Now I was also wondering, the Continental are stock tires that comes with the car? I thought that the car comes with the Michelin Pilot 4 Sport and the Continental as an optional replacement? My car just arrived at Galveston port! T minus VPC, shipping, and dealer's PDI! Super excited but if it is the Continental, then I would want those swapped out for something with more grip. Last edited by StealthFish; 03-31-2017 at 09:38 AM.. |
03-31-2017, 09:22 AM | #12 | |
913
Rep 1,427
03-31-2017, 09:43 AM | #13 |
162
Rep 460
I did upgrade to the 19" 437m style wheels. That doesn't make any sense as to why BMW would do that, have the PSS for the 18" and 20" but have mixed Continental or PSS for the 19" when they too should have just come with the PSS to begin with.
I didn't know that the cars don't come with the P4S yet. I hope I get the PSS, whatever the case is I will get the P4S or something with grip on my next tire replacement. Thanks for the info fire! |
03-31-2017, 10:25 AM | #14 | |
1163
Rep 2,561
I carry DynaPlug + pliers + goo + compressor in all my cars. I do find that BMW's compressor and good work well enough. On the cars that don't have it, I use Conti's kit: https://www.tirerack.com/accessories...nce+and+Safety https://www.amazon.com/Dynaplug-Ultr...words=dynaplug I used all four last year on a rear i3 tire, and it worked like a charm. You do need pliers to remove the screw/nail from the tread, so don't forget to have a set in your kit. DynaPlug went into the hole left by the nail, and stopped 98% of the air loss. I was still loosing ~0.25 pound of pressure per night, so I hit it with BMW's goo, and that sealed the remaining leaks until the time came to replace the tire altogether. The goo cleaned off easy, and my tire installer didn't even charge anything extra for the clean-up. YMMV, a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
03-31-2017, 01:19 PM | #15 | |
913
Rep 1,427
The consensus floating around the forums when it started happening was a supply issue. BMW and Michelin were able to cover the 18in and 20in demand with MPSS no problem, but couldn't do the same for the 19s. This was also supported by the fact that it was really hard to find MPSS in 19s anywhere during the end of 2015 and beginning of 2016. |
03-31-2017, 01:33 PM | #16 | |
General
21117
Rep 20,741
03-31-2017, 02:04 PM | #17 | ||
///Multiple
2992
Rep 4,243
I was part of a group Euro Delivery in May 2016 with 8 M2s, 2 M3s, and 2 M4s. All of the M2s and the M4 CP came with Michelin PSS (first year). The 2 M3s were split, one came with PSS and one came with Continentals. My M4 came with Continentals. After delivery, most of use did track days at Nurburgring Nordschleife, Circuit Park Zandvoort, and Spa Francorchamps. My Continentals held up better than the Michelin PSSs on the track as most of the PSSs had more wear on the outside shoulder of the front tires, but the PSS has a very soft shoulder, which is good for the street, but not so much for the track. Everyone who tracked their car replaced their front tires within a few months after the cars were redelivered in July. I was offered a new set of Michelin PSS in exchange for Michelin using my car in a display at Legends of the Autobahn in Monterey in August 2016, so my Continentals were replaced in August.
03-31-2017, 07:43 PM | #18 | ||
614
Rep 1,133
It's good to be bad
