03-24-2017, 01:01 PM | #1 |
299
Rep 517
Rubbing with 295/30 on an F80
Is anyone else having this problem?
F80 on Swift Springs running 295/30/20 in the rear. Wheel offsets are +27. Not sure what to do, to eliminate the rubbing. Can't roll the fenders and don't want to roll them either. What would the consensus out there in bimmer world? Thanks guys
-> 2018 M3 CS <- follow IG: eriggs05_m3cs
2020 Grand Cherokee Summit: Wife's 2016 BMW M3: Gone 2008 Lexus IS: Gone |
03-24-2017, 02:28 PM | #2 |
660
Rep 1,059
Option 1: Dial in more negative camber until rubbing stops; or
Option 2: Run a narrower tire; or Option 3: Run a higher offset rear wheel. Option 1 is probably the cheapest and easiest if all you need is a more aggressive alignment (within reason... ie. you don't want -3.5* camber for the street). |
eRiggs5298.50 |
03-24-2017, 04:45 PM | #3 | |
3446
Rep 4,186
-JLT- |
03-25-2017, 05:45 AM | #4 |
1836
Rep 4,203
Are you sure the rubbing is on the fender? My F82 has the Vorsteiner's and 305/30's and under pretty stiff compression they rub the inner plastic fender well but never the body fender.
03-25-2017, 06:57 AM | #5 |
General
21117
Rep 20,741
Drives: 2021 911 turbo
What brand of tire do you have?
ET27 equates to a 13mm spacer. It might be pushing it with a 295, especially if it is one with a wide tread width.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
03-25-2017, 07:28 AM | #6 |
299
Rep 517
I am running continental 5P. Def. rubbing on the body fender as you can peel some rubber from the tires off of it. I have been told don't mess with the camber. I just ordered 285s unfortunately. Really liked the width of the 295s. So now I have some brand new 295s if anyone wants them.
03-25-2017, 07:29 AM | #7 |
299
Rep 517
03-25-2017, 08:01 AM | #8 | |
3446
Rep 4,186
1) if u want to run that size wheel and tire, u need to go back to stock suspension or get a less aggressive spring (i.e. Eibach, ACS) 2) go with smaller width tire, 285 may work. (I was +18mm more aggressive on mine and ran stock 275 and had no rubbing with little more room to spare) hope this helps
-JLT- |
eRiggs5298.50 |
03-25-2017, 12:22 PM | #10 | |
General
21117
Rep 20,741
04-10-2017, 05:39 PM | #12 |
299
Rep 517
I know. So aggressive. I was upset I had to go smaller
04-10-2017, 06:05 PM | #13 | |
2118
Rep 2,014
