03-23-2017, 02:39 PM | #1 |
45
Rep 271
285 on a 10.0'' wheel?
I have a square set of apex arc 8 18x10, I plan on ordering 275/35/18 square tire set up, however I hear the tires im ordering run wider; so a 275 if more like a 285. Has anyone ran a 285 in the front before, and is this too wide for a 10'' wheel?
03-23-2017, 02:43 PM | #2 |
689
Rep 6,854
The difference is about .4" between a 275 and 285. Even if your 275's that you are getting run a little wide, they should still be fine. It will also depending on the offset of the wheels that you have.
Travis Williams
Shop ALL BMW G80 | G82 Parts Here! 480.966.3040 ext 318 Travisw@vividracing.com PM, Email, or Call Directly for aggressive BMW Member Pricing |
03-23-2017, 03:13 PM | #3 |
45
Rep 271
offset is 18x10 et25, I feel like a half inch is quite a big difference if the 275 is pushing it up front. I am just hoping someone will chime in and say they have ran 285 in the front with no rubbing issues, I guess I should also mention im lowered on ohlins road and track coils and vorshlag camber plates, I suppose I could always just add some more camber if I'm rubbing.
03-23-2017, 04:27 PM | #4 |
2760
Rep 5,483
The 285/35-18 RS3 on an 18x10 ET25 rubbed the rear fender liners up front on my car, you'll have to compare specs on that but IIRC it ran pretty close to a normal 285. It fit fine and didn't hit anything hard, but rubbed small holes where the body seam the tire can sandwich the liner. More camber won't help that situation obviously. There's plenty of clearance everywhere else assuming stock suspension, and IIRC R&T doesn't take away inner clearance if anything it should be better with a steel damper body instead of the bulbous aluminum sachs stock stuff
The key dimension up front is diameter tohugh, not width, until you get really crazy. So long as the tire is around the "standard" 275/35-18 diameter, it should be fine whether it runs wide or not. The reason the 285/35-18 RS3 rubbed was because it's 26" tall instead of 25.6" like a normal 275/3518, I've personally and others have run a 295/30-18 up front but again, that's an even shorter diameter tire Last edited by Richbot; 03-23-2017 at 04:33 PM.. |
03-25-2017, 12:22 AM | #5 | |
BimmerPost Supporting Vendor
1429
Rep 2,650
To get the full picture, what compound are you referring to and what suspension are you running? - Ryan
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
03-25-2017, 12:27 AM | #6 | |
45
Rep 271
03-25-2017, 04:45 PM | #7 | |
1429
Rep 2,650
- Ryan
03-25-2017, 09:57 PM | #9 |
F15 daddymobile
2350
Rep 3,510
03-26-2017, 10:33 AM | #10 | |
45
Rep 271
