03-22-2017, 01:04 PM | #2 |
233
Rep 1,673
You will if you have the correct width wheel for it.
Electronics Junkie, Engine Builder.
03-22-2017, 01:26 PM | #3 |
721
Rep 3,964
I currently have a 19X11 wheel with Mich PSS 295/30/19. When the tires were fresh the acceleration off the line was adequate. Now that the tires have 8k miles on them but still with 6/32nds tread left, not so much. Having cold weather hasn't helped the situation. My car is just a FBO and traction is an issue.
Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
03-22-2017, 01:42 PM | #4 | |
106
Rep 191
I'm trying to figure out if 285 to 295 makes any noticeable difference. I kind of like the idea of a shorter 285 to get the feeling of a a little more torque at low RPMs. |
03-22-2017, 03:54 PM | #5 |
5234
Rep 10,616
Go to stickier tires like RE71 or other 140-200 Treadwell tires or go to R compound like RA1 or 888 for better straight line traction. Comes at the cost of wear due to softer rubber. Can't really have it both ways.
03-23-2017, 11:42 AM | #6 | |
326
Rep 872
This was my exact complaint about these tires. Even when new I was just not impressed with the grip. I was running my 295/30/19 PSS on 10.5 inch wheels (pre-SC) and traction was always an issue. Got so bad after my SC install that I went back to stock 19in wheels w/stock sized rubber and S-04's and they were noticeably better. Running 305/30/19 RE-11's now and again the traction is much better than the PSS, even with cold temps. Impatiently waiting for summer.
AA Gen 2 Lvl 2 w/Meth; MagnaFlow catless x-pipe; Dinan Underdrive Pulley; VAC Coated Bearings; ARP Rod Bolts; Oil Diverter Valve; Dinan Strut Braces; Dinan Rear Toe Links; ECS Rear Trailing Arms; MCS 2-Way NR w/700F-1000R; GC Camber Plates; AKG 75D MM & 95A TM; CAE Shifter; Titan T-S5; StopTech ST60 380mm/ST40 355mm; MFactory DS; Zebulon Splitter; Zebulon 330 Rear Wing; Gutted w/Piper Motorsports Custom Cage; OMP WRC-R Seats
03-23-2017, 03:20 PM | #7 |
5234
Rep 10,616
PSS is 300 treadwear and RE11 is 200 treadwear. Might be a correlation there to what you say you experienced in grip differences.
03-23-2017, 03:51 PM | #8 | |
326
Rep 872
The S-04 is a 280 tire, and SC'd with 265/35/19 I had much better traction than I ever had pre-SC in my 295/30/19 PSS. They were always hard as a rock, even in the summer. Played with air pressure, checked my alignment. Nothing seemed to help. I guess my expectations were unrealistic.
03-23-2017, 04:18 PM | #9 |
2760
Rep 5,483
Tire diameter and sidewall height matter. A 285/35-19 is going to be better than an otherwise identical 295/30-19 from a low-speed straight-line traction perspective because the final gearing is a little taller and the sidewall has an extra half-inch of material in it to flex. Neither is going to be ideal for getting a high powered car off the line though, short sidewalls suck for straight line traction.
03-23-2017, 08:51 PM | #10 |
5234
Rep 10,616
Plus age can be a factor. Old hard tires don't have great traction.
The point about sidewalls is good. A little flex helps. Drag tires tend to have larger sidewalls. I have 285/35/18 PSS on 18x10.5 and I can light them up off the line in my modded NA E90M3. I doubt many street tires would eliminate wheel spin. Something like Toyota R888 or RA1 would stick but the tread wear is 100. Temperature plays a roll also. Tires are stickier in hot weather. |
03-24-2017, 06:18 AM | #11 |
758
Rep 1,408
Too many people rely on the treadwear rating. Every manufacturer has its own rating first off, but within the same brand it doesn't mean it's necessarily grippier if the rating is lower, although there is a correlation. For example, Bridgestone re050a's are 140 rated but don't have the grip of the re71r which is rated at 200 or even the PSS which is rated at 300.
But if you want the best (from what I've tested) straight line grip for street, run some R888s. |
