03-16-2017, 03:56 AM | #1 |
127
Rep 2,224
Subframe mounts/bushings
Thought this might help some others.
After having trouble with my alignment deteriorating at the track and trouble holding corners, my workshop has identified my subframe bushings are the problem. It was so bad I could see the incorrect toe in the back wheels after just a few runs. I'm stroked and supercharged and the power has caused them to wear out. My car is also very low milage, so it's a surprise. Going to install solid mounts now. Just a heads up for anyone else who are tracking and/or have a lot of power. |
03-16-2017, 07:32 AM | #2 |
11586
Rep 12,726
That's kinda weird. It seems like the four bushings would sort of center themselves. I didn't think it could get that much out of wack.
Instagram; @roastbeefmike
03-16-2017, 01:05 PM | #3 |
40
Rep 85
BMW upgraded to solid subframe bushes for the M3 GTS so I'd say this mod is a no brainer and one that doesn't have any negative affects.
Instagram - @pistonheed
Team Schirmer M3 CSL |
03-16-2017, 02:17 PM | #4 |
85
Rep 330
Might be useful if you put a gopro under there and take a video to see how much subframe moved. It wasnt mustang bad under stock power IIRC but there is definitely movement in the subframe.
03-17-2017, 09:29 PM | #6 | |
11586
Rep 12,726
Bx Tpr122.50 |
03-17-2017, 11:12 PM | #7 |
3900
Rep 4,165
Even without a supercharger or track work, solid rear subframe bushings are a great mod with zero negative effects (other than money lol)
03-19-2017, 01:57 PM | #9 |
123
Rep 891
RB was that with oem subframe and diff bushings?
03-19-2017, 08:10 PM | #10 |
11586
Rep 12,726
i don't think it is necessarily worse with a supercharger, and here is my reasoning. these bushings (any bushings) are going to flex until they reach their limit of flex against the bushing housing/etc. and that is about what you're seeing in the video. the bushings are only going to flex until their limit and then the tires are going to break loose and the tension is going to be relieved. if it only takes 300 ft/lbs of torque to bring the bushings to their flex limit, 500 ft/lbs isn't going to flex them more, you're just going to exceed the traction of the tires sooner.
03-19-2017, 08:17 PM | #11 |
11586
Rep 12,726
yes sir. go look under your car and observe the subframe and everything attached to it. then watch the video again. you'll be surprised at how much that whole huge assembly is moving. that is your entire rear suspension with a bout 1/2 to 3/4" of slop. plus, the rotation of the differential contributes to less traction.
03-20-2017, 10:23 PM | #12 |
127
Rep 2,224
40,000km. Subframe moves and throws our rear toe, which throws out entire alignment. Happens after just a few laps around the track and culprit is worn subframe bushings/mounts apparently.
