03-13-2017, 03:20 PM | #1 |
27
Rep 151
Any issue to run 285/40/18 on 18*10.5 et25
Still researching about the 18" wheels. Hard to find a set of wheels with right offset. Not sure if I can run 265/40/18 on 18*9.5 et22, and 285/40/18 on 18*10.5 et 25. Will there be any rubbing issues by running these on M3 with ZCP (not lowered). I think 265/35/18 and 285/35/18 will be better, but it gonna make about 3.7% difference with the original overall diameter, not sure if an alignment is need or not. or there will be other problems other than speed variance.
03-13-2017, 04:42 PM | #2 |
Recovering Mazda Addict
19
Rep 127
Which tires? Shouldn't be any issue unless they're extremely wide r-comps.
I'm damn close to pulling the trigger on a set of 275/40-18 R-S4s... 75% chance they fit, 25% chance they'll rub the fender liner on turns by my measurements. (Which should be fixable with a little heat gun massaging if I'm looking right) Change wheels won't require an alignment, but if you can get more neg camber that would be good... Edit- however those rears at et25 may be problematic... I'm looking 11s around et40-44 Anyway, all about the brand and tread width up front. We're close enough that it's going to come down to the details... |
03-13-2017, 11:26 PM | #3 | |
3138
Rep 2,953
The picture above is 285/40/18 Hankook RS3 on Volk ZE40 18x10.5 +25 |
03-14-2017, 12:22 AM | #4 |
27
Rep 151
03-14-2017, 12:27 AM | #5 |
3138
Rep 2,953
