03-13-2017, 06:50 AM | #1 |
Rep 123
TPMS for F80
Do all F80 M3s use the same sensors? What is the difference between 36106856209 and 36106881890 (http://www.realoem.com/bmw/enUS/show...agId=36_2027)?
Thank you |
03-14-2017, 11:25 AM | #3 |
1034
Rep 24,709
Drives: BMW E39 M5, F10 M5, F80 M3
03-16-2017, 10:43 AM | #4 |
10
Rep 30
dup
'17 M3 ZCP Tanzanite Blue / Golden Brown '95 M3 GTS4/CM S54 Race Car Last edited by RoundelM5; 03-16-2017 at 10:52 AM.. |
03-16-2017, 10:51 AM | #5 |
10
Rep 30
I just picked up '17 M3 last month and needed to order TPMS for winter setup. Dealer informed me that PN updated and ..209 was superceded in Jan '17 by 36-10-6-881-890. FWIW, I purchased ...890 on this recommendation and they work perfectly in my Jan build F80 M3.
Screen shot from my order...
'17 M3 ZCP Tanzanite Blue / Golden Brown '95 M3 GTS4/CM S54 Race Car |
03-16-2017, 12:09 PM | #6 |
BimmerPost Supporting Vendor
1267
Rep 869
I have a mix of those sensors (3 of the 890 and 1 of the 209) on my aftermarket wheels and can confirm I didn't have any issues
Speed & Tech Motoring
23585 Overland Drive, Unit 178 Sterling, VA 20166 (Headquarters) 23541 Pebble Run Place, Unit 140 Sterling, VA 20166 (Satellite shop) |
03-19-2017, 03:53 AM | #7 |
12
Rep 42
All matters best thing do to is get a set of 4 sensors and have a shop program each set of rims to the cars TPMS module then you won't have any issues when changing rims that's what I did summer and winter tires works great I have a TPMS and a obd2 scanners did it all with my own equipment very easy once you get the hang
