03-11-2017, 06:35 PM | #1 |
105
Rep 236
Can't remove the lug nuts of my wheels
My car is 2017 M4 coupe with ZCP and 666M wheel.
I just bought a spare tire in case I get flat tire during trip, which is terrible. This is my DD car. Today I just wanted to try if I could replace the wheel & tire myself. I used a 21" lug wrench which is very solid, but I can't remove the lug nuts of 666M wheels. I even stood on it and jumped. 21" multiply my weight is at least 250 ftlb. I tried 3 lug nuts, all failed. Any one has idea? I was doing it counter clock-wise (don't tell me it was wrong). Thanks for your help. |
03-11-2017, 07:18 PM | #2 |
6580
Rep 5,304
Get a long pole that you can sleeve over the breaker bar (like the pole on a hydraulic jack). This should give you more than 3ft of leverage which is plenty to loosen with your own arm strength. After that, be sure to torque it down to the correct ft/lb.
03-11-2017, 07:23 PM | #4 |
105
Rep 236
03-11-2017, 07:51 PM | #5 |
174
Rep 207
Bmw re torqued them all for free but charged me I think 30$ to remove the stripped lug. I stripped it really bad though almost completely round. They had to drill it out. I'm saying before u do damage they won't cover take to them n let them remove
03-11-2017, 08:51 PM | #6 |
310
Rep 408
Electric or pneumatic impact wrench with a quality, correct sized socket. If you have to hammer the socket to get it in and seated completely on the nut then do so (since the lug nut is damaged it may not accept the correct sized socket without persuasion).
I've seen several people strip their lugs using a breaker bar. They don't seat the socket completely onto the nut and/or when they apply pressure to the bar, they do so in a way that pries the socket off the lug nut as they are trying to loosen it. Impact wrench is more foolproof (higher financial cost though) for removing lug nuts. |
03-26-2017, 12:15 PM | #7 |
1104
Rep 1,083
Use a RYOBI 18V 1/2 Impact and set speed at #3. Works great, even with rusted suspension parts. Only $129.
http://www.homedepot.com/p/Ryobi-ONE...FRe2wAodrJIHPQ This can be prevented by using a drop of copper anti-seize on the thread of the bolt. Keep in mind when using anti-seize, you must decrease torque by 20%. So only torque to 95ft-lb with anti-seize, which is considered "lubricated" torque specs. I've been using copper anti-seize for over 15yrs and even tracked my cars, never had any issues with wheel bolts seizing up.
Jimmy | BMW Addict | Signature Performance Wheels | OBSESSED WITH PERFECTION | IG: Signature_BMW | Email: jimmy@signaturewheel.com
SanchoDivine553.50 |
03-27-2017, 04:59 PM | #8 | |
///Multiple
2992
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
Regarding using anti-seize on lug bolts, there is decidedly mixed advice on this topic. Do your own research before following the above advice. I've been tracking cars for over 20 years and I've never used an anti-seize on my lug bolts/nuts and I've never had a problem removing them. The key is to make sure that your lug bolts/nuts don't get overtorqued. Take your own breaker bar and torque wrench to the tire installer and make sure that you check them after the installation. If you can't get them off, have the installer loosen them.
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
