02-26-2017, 02:01 PM | #1 |
203
Rep 699
Replacing front brake rotors
I have a question for those who track on OEM brake rotors and do their own maintenance: practically speaking, when do you replace the rotors?
I know the theory, i.e. replace either when the rotors reach minimum thickness (28.4mm down from original 30mm for the E9x), or when there are long cracks connecting the holes. But what if there are no cracks but you are getting close to the minimum thickness? Do you proactively replace the rotors? Conversely, do you not mind going down below the recommendation to 28mm, say? For reference, I tend to replace brake pads once they are noticeable thinner than the backing plate; I don't like to run them down further because of the increased heat load when they are over 60% gone. I am not sure the same applies to the massive rotors, where the theoretical minimum corresponds to only 5% of the material gone. Anyhow, happy to hear experiences or practical tips, thanks. |
02-26-2017, 06:08 PM | #3 |
75
Rep 387
Rotors are replaced so that you have at least minimum thickness at the END of an event. Thats assuming that there are no issues with cracks.
Pads need thermal capacity that comes from thickness. Don't play the minimums when it comes to brakes. |
scotty_miller184.50 |
02-27-2017, 04:54 PM | #4 |
Retired Curmudgeon
2985
Rep 4,047
Most rotors don't wear very fast. I don't have data on stock E9xM3 rotors, but on good rotors I'd be surprised to see more than 0.001 - 0.002" wear with race pads over a track weekend. This is track dependent with significantly more wear at Laguna than at Chuckwalla.
That being said, a failing rotor will give you a "that won't buff out" situation so err on the side of being conservative.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
02-27-2017, 05:28 PM | #5 |
1889
Rep 5,506
I replace the rotors when there's a noticeable ledge on the edge.
Depending on what pads you run, a set of rotors should last many years worth of track days.
Auto Detailing Enthusiast!
02-27-2017, 09:12 PM | #6 | |
Stop the hate, get a V8
3850
Rep 8,625
Thermal capacity decreases as they wear, as you said. If they are nearing the minimum, I would just replace them. Brakes (and safety equipment) is not something you should pinch pennies on. I agree with everything that has been posted in this thread. OP, what pads do you use?
Past: 2011.5 M3 sedan ZCP |
02-27-2017, 09:57 PM | #7 |
203
Rep 699
I am using Stoptech Street performance pads, which worked very well for me at intermediate track driving level. The rotor thickness seems to have gone mostly over the last 10 track days or so, it feels like rotor wear is a sharply increasing function of nudging up of my average speed on the track and hence of the necessary braking. All in all, I don't complain after 42K miles and 22 track days..
Thanks all for the input; I already got the new rotors, so ready to install. I'll measure the thickness again and might squeeze in the first one-day event of the year before I make the change as then I can change pads and rotors together.... |
02-28-2017, 03:16 AM | #8 |
239
Rep 479
I replace mine when I can feel a lip and below minimum thickness. I have tracked with rotors having a lip but not below minimum thickness, and no issues. I replaced my OEM rotors for ECS two piece rotors, in the front, becuase it was roughly the same price as OEM but better cooling.
02-28-2017, 09:29 AM | #9 |
Retired Curmudgeon
2985
Rep 4,047
Could always give the rotors the float test. Works every time on questionable items.
02-28-2017, 09:42 AM | #10 | |
///M Powered for Life
11487
Rep 10,329
Since starting to track I have never worn a rotor down to min thickness. They always crack first |
03-09-2017, 02:34 PM | #11 | |
196
Rep 386
03-09-2017, 03:07 PM | #12 | |
196
Rep 386
03-09-2017, 07:53 PM | #13 | |
239
Rep 479
I can say they take track abuse well. Currently has 4 track weekends on em, with DTC-70 pads, and the rings still look good. |
03-10-2017, 07:25 AM | #14 | |
196
Rep 386
03-10-2017, 08:40 AM | #15 | |
203
Rep 699
03-10-2017, 09:54 AM | #16 |
2760
Rep 5,483
Stock rotors are two-piece also, it's just a different arrangement than most aftermarket setups and the attachment of the hat to the ring blocks some of the vanes. The ECS rotors have a higher vane count and a different attachment mechanism which they claim allows for better air flow. The ECS rotors are also a bit lighter than stock
03-10-2017, 01:12 PM | #17 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
If heat cracks aren't an issue...you can run them on the track to min thickness. You need to be aware that your pads will likely run hotter and not last as long.
You DO need the check the backside of the rotor for heat cracking. This means pulling off the rotor. You'll be surprised...I've typically had similar or worse heat cracks on the backside.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
03-10-2017, 08:15 PM | #18 | |
11586
Rep 12,726
https://www.essexparts.com/essex-des...p5060355mm-e92
Instagram; @roastbeefmike
03-13-2017, 07:32 AM | #19 |
239
Rep 479
Damn thats kinda lame :/ but I'll probably still go with them. They are pretty good at the track for me. Haven't had overheating issues with them.
