02-26-2017, 01:32 PM | #1 |
408
Rep 2,171
diagnose my rear tire wear.. new nt01, 1 trackday
Question for experienced track rats..
This is my NT01, rear, after 1 track day.. 7 sessions, 20 minutes.. around 1:47 pace at laguna. right side is outside edge. Do I need more rear neg camber? |
02-26-2017, 01:40 PM | #2 |
11586
Rep 12,726
How do your fronts look? I get a similar wear, but by the time I have rotated them to the front and they get bald, the tires have pretty even wear and they are spent.
Instagram; @roastbeefmike
02-26-2017, 02:07 PM | #3 |
408
Rep 2,171
fronts look much more even. unfortunately this is a f82 and i'm running an non square setup - 275/305. So can't rotate.. my alignment guy says it might need adjustment, adjust toe or somethign.. he'll take a look next week.
02-27-2017, 04:04 AM | #4 |
11586
Rep 12,726
it doesn't really look like you're scrubbing them enough to really wear the edges as rapidly as you think. meaning- the tires look pretty clean for a track day. what hot psi were you running them at? i'm thinking maybe too low of psi at laguna might cause more edge wear. i run a little lower psi at the big roval tracks where i'm scrubbing at highers speeds and creating a lot of heat (more hot pressure), but at laguna seca, i think my sweet spot has been 32 psi hot.
w00tw00t408.00 |
02-27-2017, 05:06 PM | #6 |
Retired Curmudgeon
2985
Rep 4,047
"Moar negative camber please" is what that tire is telling me.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
02-28-2017, 10:51 AM | #11 | |
2760
Rep 5,483
Also the sjoulder will look worse than it really is if you drive a cooldown lap without loading them up because the outside shoulder gets hot and then doesn't get scrubbed against the road during the cool-down/paddock driving
02-28-2017, 04:10 PM | #13 | |
408
Rep 2,171
02-28-2017, 05:05 PM | #15 |
11586
Rep 12,726
32 is the sweet spot for me at Laguna. I forgot to check pressures on a new set of tires once and I was struggling for traction in the front and back. It makes a big difference.
02-28-2017, 05:33 PM | #16 |
408
Rep 2,171
ah, that's why I was so slow... hehe, next time I'll lower to 32.. trying to get to 1:45 at laguna..
02-28-2017, 05:38 PM | #17 |
2147
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
Diagnose mine - 1 track day:
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
02-28-2017, 05:39 PM | #18 |
11586
Rep 12,726
Diagnosis: too much skinny pedal fun.
02-28-2017, 06:23 PM | #19 |
11817
Rep 23,187
03-01-2017, 07:25 PM | #22 |
64
Rep 258
Considering the right side is the outter edge. Either a, you have too much camber for that track and/or you ability, or two you havent pushed hard enough. If you notice that line by the right side, thats where your grip potential is ending. Meaning you have about a half inch ish (im not there) of tire potential. Personally i think youre ok, you have room to grow.
