02-25-2017, 09:10 AM | #1 |
Rep 11
Goldielocks wheel se up?
I'm a bit of a newb but have been searching and reading as much as I can.
Will a company like forgeline build a set of wheels with the correct front and back offset so you don't have to run wheel spacers and fit the 380mm calipers? What's the story on square setups? I read in another thread they can cause oversteer at higher speeds? |
02-26-2017, 02:33 AM | #2 | |
175
Rep 513
From specs for brakes, to widths, to offsets. Everything you want. Square setups work fine. Lots of people use them. Biggest bonus is that you can rotate tires to get some extended usage out of them. |
