02-22-2017, 07:22 AM | #1 |
802
Rep 1,566
19x9 +15 Fitment
I'm looking at buying some European spec AG M359s which have a slightly more aggressive front offset than the US version. These are +15 while US are +18 and OEM are +31.
Wondering if a 19x9 +15 wheel on stock suspension will poke past the fender or require any camber adjustment to look flush? Also, will I be able to run a 255/35/19 front tire or will I only be able to fit 245/35 with such an aggressive offset? I've got my ESS s/c intake filter behind the wheel liner so that may reduce the already limited space I have to work with by a bit.
02-22-2017, 07:52 AM | #3 |
802
Rep 1,566
I think you're right, I've seen some people mention rubbing with the +18 359s on 255/35 so these would be even more likely to rub. I'm ok with sticking to 245/35 tires as long as these wheels won't look too aggressive with stock suspension.
02-22-2017, 08:57 AM | #4 |
256
Rep 1,174
02-27-2017, 10:15 AM | #5 |
165
Rep 1,402
Drives: 06' E46 M3 ZCP
That's not entirely true. Depends on how low you are running 265/30 on +18 with no rubbing. I just ordered those exact specs and saw nothing about rubbing. This is also on a 9.5 not a 9
19’ F90 M5C | Signature VS-104 | M-Performance | IND | H&R
06’ E46 M3 ZCP | Karbonius | Ohlins | Vorshlag | Turner | Kassel | IND | Status Gruppe | Macht Schnell 03' E39 M5 | 100% Stock |
03-01-2017, 03:02 AM | #6 |
175
Rep 513
Not the same.
On a 19x9 255/35/19, the tire isn't stretched. It actually bulges, and it's taller. 265/30/19 is a physically shorter tire than 255/35/19, or even 245/35/19. What rubs, is the fender liner, and that's due to the height of the tire. |
03-01-2017, 11:21 AM | #7 |
165
Rep 1,402
Gotcha.
03-01-2017, 12:01 PM | #8 |
612
Rep 1,326
i'm running 19x9.5 et12 with 255/35/19 Michelin PSS at -2 deg camber. Only slight rubbing on large dips.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
