02-16-2017, 04:58 PM | #1 |
Rep 61
Apex RS-7 265/285 Fitment
I'm wondering if i'm going to run into any problems with rubbing with this setup.
Car: 08 E92 M3 Wheels w/ Offsets: Apex PS-7 - (F) 19x9.5 +22, (R) 19x10.5 +22 Spacers: (F)15 mm (R)12.5 mm Tires / Miles: Bridgestone Pole Position S04 - (F) 265/35/19, (R) 285/35/19; Suspension: Swift Spec-R Springs Fender Modifications: (F) None (R) None I've already ordered the wheels. Waiting on picking tires. |
02-17-2017, 03:00 AM | #2 |
170
Rep 216
Ran a similar set up before and I had no issues with rub. Looks like you'll be good!
Instagram: @m.ch.ael
Current: Yas Marina Blue M4 Current : Mini Cooper S R56 Sold: E46 M3/E92 M3 KW | Fall line | Volk Racing | Recaro | Bayoptiks | BM3 | THOR | IND | |
02-17-2017, 04:04 AM | #3 |
12
Rep 94
I had 285/30's with a 10mm on the rear, same wheel specs. No rub, though a 12.5mm might make it close, especially with no camber. Also, 35's might be too thick for the rear, front will be fine. And, front rubbed on full-lock with 265/35/19's, no spacers.
.ck |
02-17-2017, 03:20 PM | #4 |
Admiral
931
Rep 3,886
No issues.
Edit: didn't realize these are 19's. As mentioned below, too tall. My 255/35/19 already rub a bit of the fender liner. Also, you don't need those spacers.
2020 FORD RAPTOR 2014 F15 X5 | M-SPORT SOLD 2011 SG E90 M3 | 2008 AW E90 M3 | 2004 E46 M3 |
02-17-2017, 03:23 PM | #5 |
721
Rep 3,964
You guys...on the front a 265/35/19 is going to rub like hell and not because of the width but the height. Also a 285/35/19 is almost a 27" tall tire, way to tall for the rear. I run a 275/30/19 on a 19X10 ET25 with no rub on the front. To the OP, you need to run a 30 series tire not a 35.
Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk Last edited by Dave07997S; 02-17-2017 at 03:44 PM.. |
02-18-2017, 03:11 PM | #6 |
BimmerPost Supporting Vendor
1427
Rep 2,650
Dave is correct, the tire sizes are incorrect. They are too tall, especially in the rear. In terms of the wheel fitment, they will bolt on just fine, but do not need the spacers you have listed.
In terms of tires, you should run 265/30-19 or 275/30-19 front. In the rear, 285/30-19 or 295/30-19. - Ryan
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 02-18-2017 at 03:46 PM.. |
02-20-2017, 11:47 PM | #7 |
Rep 61
Thanks for all the input. I listed the spacers cause' I already have them on there. I'll be taking them off. I went with 265/30-19 front 285/30-19 to be on the safe side. Trying out the Kumho Ecsta PS91's.
02-21-2017, 11:53 AM | #8 |
Rep 61
Hi guys, don't want to thread jack but it looks like OP has his answer. I have a question out to several folks that you all may be able to help me answer. I've bought some Vorsteiner vff 101's (19x9.5 and 19x10.5 - offset of 22 and 25) and I'm coming from a stock Comp package with ZCP 359's and I've been told several different things regarding tire size. First I got 255/35/19 in the front and 275/35/19 in the rear from a tire rack support person and then 255/35/19 and 285/35/19 from a moderator and then.... 275/30/19 and 295/30/19 from a Vorsteiner rep. Slightly confused at this point so I'm searching threads and looking for help
2012 E92 Mineral White w/ Comp Pkg. DCT / MPE /Eventuri Intake / Evolve Stg. 1/ Vorsteiner V-FF 101's
02-26-2017, 05:14 AM | #9 |
Rep 61
Got the wheels and tires on and everything fits great! No rubbing that i've noticed thus far.
View post on imgur.com View post on imgur.com |
6ixSpd6014.50 |
02-26-2017, 03:13 PM | #11 | |
721
Rep 3,964
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
