02-09-2017, 05:08 PM | #1 |
592
Rep 769
Got my car weighed today
Had some business by a scrap yard today so after I was done I popped in to see if they would let me use their scales and they said yes! I'm not nearly as track ready as most of you guys here, but I was curious how much I weigh now with a decrease from the full RPI exhaust and an increase from my Forgestars. My E92 has most every option like navigation, heated seats, individual audio, etc, aside from cold weather package and headlight washers. I had exactly 1/4 tank of gas when I weighed (the low tank reminder went off right when I was pulling off the scale. The only other weight in the car was miscellaneous stuff like phone, wallet, umbrella, etc...probably like 10-20 lbs max...and I stepped out of the car. The only caveat is they said their scales automatically round up to the nearest 10 lbs, so not perfect but close enough for refetence. And I double checked the weight on both the entrance and exit scale to be sure...and to keep them honest
All in all, fairly satisfied with 3,520 lbs, but I could definitely use a diet if I get more serious about track. Also, how much gas is everyone else running with on track? I've just been starting with a full tank and let it drop to half then fill it back up. Slightly worried about starving the fuel pump in long or hard corners. |
02-09-2017, 05:39 PM | #2 |
184
Rep 518
I was expecting more, too. Which transmission? Carbon roof?
2003 M3 | SMG | KW V1 | Apex ARC-8s | 3.85 LSD | Cobra Nogaro | S2R Tuning Sunroof Delete | Billy Boat Section 3
02-09-2017, 05:42 PM | #3 | |
592
Rep 769
02-09-2017, 06:40 PM | #4 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
1/4 tank of gas so that means a full tank is about 84 lbs more.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
02-09-2017, 06:57 PM | #5 |
Save the Manuals
1714
Rep 2,937
That is excellent
Encouraging....Considering mine has the minimum of add ons
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
02-09-2017, 08:59 PM | #6 | |
592
Rep 769
So my weight would be something like: Empty Tank: 3,495 1/4 Tank: 3,520 1/2 Tank: 3,545 3/4 Tank: 3,570 Full Tank: 3,595 |
02-10-2017, 10:19 AM | #9 | |
2760
Rep 5,483
Edit again missed your fuel starve question. When I autocrossed the car on Hoosiers I never experienced fuel starve no matter how low I ran the tank. Routinely autocrossed it at or below 1/8 tank and never any fuel starve
Edit so I got curious and threw it on my scales it is at 3490 with 5/8 tank now without all the floor mats and trunk junk in it. Those are worth 20lb so I guess I will fill the tank next time I drive it and get an apples to apples idea add that to 3510 and see what all my anal retentive weight loss efforts have really netted
02-10-2017, 05:02 PM | #10 |
115
Rep 1,470
Mine is 3550 with a 1/2 tank of gas and no driver. Carbon roof and DCT.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
02-10-2017, 06:16 PM | #11 |
379
Rep 875
http://www.m3post.com/forums/showthread.php?t=1268063
I was at 3,651 lbs with full tank of gas. E90 with moonroof ( ) 6 MT/Nav. Damn the moonroof. Damn all of it. |
02-10-2017, 06:18 PM | #12 |
1571
Rep 8,076
I weighed my stripped out E46 M3 and it came in at 2560 (+/- 20 lbs) - 1/4 tank, no driver, no carbon fiber anything.
I might weigh my E90 soon. It should be pretty light - DCT, manual cloth seats, no I-drive, no sunroof.
02-10-2017, 06:26 PM | #13 |
379
Rep 875
02-10-2017, 06:32 PM | #14 |
1571
Rep 8,076
That would sound pretty close. The manual seats are significantly lighter than the powered seats but the DCT adds quite a bit back.
02-10-2017, 08:15 PM | #15 |
2760
Rep 5,483
I'm on the hunt for a set of used ratty manual E90 sport seats to swap my novillo cushions/covers over to, or a set of black novillo manual E90M seats but so far no dice
02-10-2017, 10:13 PM | #16 | |
1571
Rep 8,076
While I love my Monte Carlo Blue E90...its basically a track build with a $4500 paint job. Kind of idiotic. Since I DD the E90, I wouldn't mind swapping in black leather/power seats. Not sure what I need to do to make the power seats work.
02-11-2017, 07:19 AM | #18 | |
2739
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
02-11-2017, 08:23 AM | #19 |
1571
Rep 8,076
That is pretty rare!
02-11-2017, 08:46 AM | #20 |
450
Rep 465
The DCT is about 45lbs heavier than a 6MT...
"Racing is life. Anything before or after is just waiting." Steve MCQueen
02-11-2017, 09:52 AM | #21 |
1571
Rep 8,076
Maybe just the transmission but there's wiring, control module, and 9L of fluid vs 2L of fluid.
02-11-2017, 12:28 PM | #22 |
2760
Rep 5,483
