01-27-2017, 12:21 PM | #1 |
41
Rep 147
Drives: E92 M3
Which one perfect fit on my rims
I have e92 m3 with 19 volk rays ze40, 9.5 et 22 and 10.5 et 35, for rear used 15mm spacer. Now im using 245/35 and 275/35. The front tire pretty stretch the rear bit stretch.
Im planning to get advan neova ad08r For the rear i will used 295 30 Should i use 275 30 or 255 35 for front? I like profile 35 think it more comfort but will it stretch tire? I dont want any rubbing |
01-27-2017, 12:31 PM | #2 |
2739
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
a 275/30 and a 255/35 tire have a very similar sidewall height. The "35" is a ratio not a fixed height. In other words the side-wall height comparison is: 275 x 0.30 = 82.5 mm, while 255 x 0.35 = 89.25 mm. The 255/35 is taller by 6.75mm. Not sure whether you will feel the difference in ride quality. I would personally run a 275/30 in the front but that will require about -1.6 degrees of camber.
You know as well as anyone how much it will be stretched considering you are currently running 245/35 on the same wheels.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
01-28-2017, 10:09 PM | #3 | |
41
Rep 147
Drives: E92 M3
01-30-2017, 06:48 AM | #4 |
41
Rep 147
Drives: E92 M3
I heard from my friend is 275/30 will rub inner fender?
02-01-2017, 12:16 AM | #5 |
BimmerPost Supporting Vendor
1428
Rep 2,650
Slicer's comment in regards to sidewall height it correct.
275/30-19 will fit just fine on a 19x9.5" ET22, many of our customers run this same tire on 19x10" ET25 wheels up front. Depending on vehicle ride height and tire brand, you may slightly scrub the fender liners at full lock or upon compression, but overall this is a good fitment. We do not find that negative camber is necessary, however it certainly helps gain extra outer fender clerance. In the rear, you may need to reduce the spacer thickness you are currently using to somthing a touch slimmer, like 12mm or 10mm. Wait until you get the 295's mounted, and you can uninstall the 15mm spacers at that time if need be. - Ryan
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 02-01-2017 at 12:25 AM.. |
dry8740.50 |
02-02-2017, 12:23 AM | #7 | |
501
Rep 1,236
02-02-2017, 12:43 AM | #8 | |
1428
Rep 2,650
- Ryan
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
///MPower15501.00 |
02-02-2017, 04:57 PM | #9 | |
41
Rep 147
Drives: E92 M3
For rear if im using 295 30, how much spacer u think best for me? For best look but not rub Thx so much |
02-02-2017, 05:42 PM | #10 | |
1428
Rep 2,650
In the rear, I would first mount the 295/30-19 AD08R's and then test fit without spacers. These tires run a touch wider then your average street tire, therefore its best to get an idea of what type of rear fender clearance you are working with. Once you have a benchmark, you can measure from the tire to the rear fender edge to understand how much room you have for a spacer. Depending on your ride height and alignment (camber settings), I would say 5mm or 10mm spacers can be used. - Ryan
dry8740.50 |
02-03-2017, 01:02 PM | #11 | ||
41
Rep 147
Drives: E92 M3
02-03-2017, 05:28 PM | #12 |
1428
Rep 2,650
