01-27-2017, 10:08 AM | #1 |
175
Rep 624
P00BC Code after Exhaust Install
Hey Guys, so I've been getting the P00BC Code with engine light on after installing the RPI GT Catback exhaust.
Is this a common issue, is there a leak in my exhaust?
2013 M5 Space Gray, Piano Black|Night Vision|Every option|6MT|RW Carbon front Lip|Vorsteiner Rear Diffuser|
2019 x7 50i White, Loaded | chrome delete | black grill | Previous: 2015 X5 Graphite, |All options| - 2014 435i Xdrive Msport, |Fully Loaded|6MT|FBO|JB4|Front,side,rear lips/spoilers|- 2015 320i Xdrive, |Wife's beater| - 2008 535i Xdrive |
01-27-2017, 10:46 AM | #3 |
143
Rep 715
I looked up the fault code in Rheingold and it has something to do with your Mass Air Meters: Signal or air mass too low.
You should try cleaning your MAF's. It may be that your engine is flowing slightly more air and it's triggering the fault. The system is very sensitive.
2015 M5 - Singapore Grey Metallic - Silverstone Full Merino Interior - Executive Pack - Drivers Assist Pack -Comp Pack -
01-27-2017, 11:54 AM | #4 |
175
Rep 624
Thanks guys, I will try to plug the vacuum lines that was on the OEM exhaust and report back. If that doesn't work then will spray the MAF sensor with some CRC spray.
01-30-2017, 03:56 PM | #5 |
175
Rep 624
Ok guys, here's a quick update:
I plugged the hoses with golf tees and also zip ties. The code went away after about 20 miles and maybe after another 40 miles of driving it came back on. The weird thing is 10 miles later the code disappeared again and it's stayed off. For anyone with aftermarket exhaust, make sure you plug the hoses though. It definitely brought my car back alive, with the hoses open the car felt sluggish like it was only about 300HP but with the hoses closed the car feels like it should!
01-31-2017, 08:14 AM | #6 | |
49
Rep 857
Glad to hear that worked for you, the vacuum lines being plugged are a must now you can enjoy the exhaust and the car how it's supposed to be!
02-01-2017, 01:42 PM | #7 |
175
Rep 624
You know what's weird is when I drive with WOT on sport and sport+ the engine light will come on.
BUT if I leave it in efficient setting and drive for 20+ miles the code will disappear by itself. Anyone know why this is happening?
02-01-2017, 01:44 PM | #8 |
49
Rep 857
Is it the same exact code that comes up when you do that? have you read the code or just see that the light comes on?
02-01-2017, 05:04 PM | #9 |
175
Rep 624
I'm assuming it's the same code, didn't get a chance to pull it before it went away.
02-03-2017, 09:37 PM | #10 | |
175
Rep 624
P00BC P0171 the second code is a new code. Anyone know what's going on?
02-10-2017, 01:03 PM | #11 |
49
Rep 857
P0171 is bank 1 lean mixture. as previously mentioned i would check your air intake system for any issues. make sure your filters are good, and that the airboxes and piping to the turbo inlets are tight. if there is an air leak after the mass airflow sensor, that can cause a lean condition. make sure nothing obvious is wrong in the engine bay and go from there. hope this helps.
02-10-2017, 01:08 PM | #12 |
143
Rep 715
^+1
Also clean your MAFS just to rule that out.
02-10-2017, 10:38 PM | #13 |
175
Rep 624
The MAFS are clean, it's weird. The CEL has been off for about a week now and hasn't come back on.
One thing I did notice with the car though after 2 weeks of driving with the RPI exhaust. I feel like there is loss in torque and the car doesn't feel as fast as it did with the oem exhaust although the RPI sounds much better. I've plugged the valve hoses with golf tee so it shouldn't be leaking there.
02-11-2017, 02:20 AM | #15 | |
175
Rep 624
02-11-2017, 06:31 AM | #16 | |
167
Rep 501
2016 McLaren MSO 570S | 2018 Ford Raptor | @alpha7even
02-11-2017, 02:27 PM | #17 |
243
Rep 881
Agreed. Also, when does the P0171 code come on, cruising, @WOT? Pick up a cheap code scanner so you can log which code comes on at the current driving conditions.
2014 "AW/SO"me M5
Mission Performance/3.5 Bar RK Autowerks/ CSF ICs SSP Spec-R KW V3/ Corsa Axle back |
