01-27-2017, 08:36 AM | #1 |
90
Rep 403
255/275 AD08R on ZCP wheels
Will these rub on an E92 with the competition package? The specs on tirerack show they are a very wide tire. After searching I see they fit nicely on the E90 but couldn't get a definitive answer on the coupe.
01-27-2017, 12:35 PM | #2 |
2746
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Coupe and sedan have essentially the same clearance on the M3. It was only the non-M cars that had clearance differences between the two. You will be fine. Keep in mind most people run 12mm to 15mm spacers with their ZCP wheels. You are proposing running a tire that is 10mm wider which basically adds 5mm on each side. The AD08's run more square at the shoulder than other tires but that might add only a few more mm's to the clearance needs. You have plenty of room to work with.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
01-27-2017, 07:12 PM | #4 |
215
Rep 832
I am running this setup, at it did slightly rub in the front for a couple days. I run them at 33psi all around and they are fine. Great tire and perfect sizes, no regrets. You will have a lot more fun using launch control.
01-27-2017, 10:23 PM | #6 |
504
Rep 1,055
I ran F 255/35 AD08R on a 9.5" ET 28 wheel and experienced very slight rub on full lock as mentioned by opihi5.
I have them for sale now if interested!
aFe Stage 2 Intake | BW Race X-Pipe | UUC Corsa Exhaust | Alpine MS Tune | Brembo GT
01-28-2017, 06:27 AM | #8 |
175
Rep 513
01-28-2017, 03:02 PM | #9 |
90
Rep 403
Wheelset and tires are for HPDE and track days only. About 100 mile drive to and from the track then the they come off for my daily 18" wheels. Can't have any rubbing at suspension limits when bombing around corners.
01-28-2017, 04:48 PM | #10 | |
Stop the hate, get a V8
3853
Rep 8,625
They don't rub on my E90 but it's a pretty tight fit since the sidewalls are a bit more square than the PSS and other tires of the same size. I don't see why it would be any different on the E92, but I'll let someone else chime in here.
Past: 2011.5 M3 sedan ZCP |
01-28-2017, 04:53 PM | #11 | |
3853
Rep 8,625
If anything, wider tires would be less likely to rub at the track since you are not going lock-to-lock on the steering wheel.
01-28-2017, 05:46 PM | #13 |
68
Rep 614
01-28-2017, 09:13 PM | #15 |
215
Rep 832
I forgot to mention i am running 12mm spacers front and no spacers in the rear, 10mm rear rubbed very hard for me so i'm picking up 5mm.
01-30-2017, 06:27 PM | #17 |
90
Rep 403
01-30-2017, 07:35 PM | #18 | |
1890
Rep 5,508
I didn't rub with 10mm spacers and PSS tires in the same size in the rear. The AD08R are very square and stiff compared to PSS.
Auto Detailing Enthusiast!
02-06-2017, 02:00 PM | #19 |
504
Rep 1,055
02-07-2017, 07:27 PM | #20 |
90
Rep 403
275/295 in AD08R's? Wow.
I ended up ordering a set of 255/275 from tirerack. Any issues storing these tires in an unheated garage? Won't get below freezing but might get to 40' occasionally. |
