01-22-2017, 11:35 AM | #1 |
27
Rep 146
Track pads only in the front
When I used to take my E36 to the track, I would swap out only my front pads for track pads. This was very common and sufficient for HPDE on the e36.
Is it also the case for the e92 m3? Are there any reasons not to swap in track pads only in the front? |
01-22-2017, 03:03 PM | #2 |
450
Rep 465
E9x m3 is not e36. It is much heavier and more powerful.
Stock rear brake pads are not sufficient for this car on the track.
"Racing is life. Anything before or after is just waiting." Steve MCQueen
01-23-2017, 02:13 PM | #4 |
185
Rep 936
I wouldn't try and skimp out on one of your most crucial components at the track :
You'll find me at the track
BMW CCA Club Racing #905 Instagram: scottynotpippen |
01-23-2017, 04:05 PM | #5 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
I've done that on my E46 but wouldn't dream of doing that in my E90. Mostly because you'll cook your front pads really fast. If you drive M mode or DSC on, DSC will put a beatdown on the rears.
Other than that...your brakes will work fine with front track pads, stock rear pads with DSC off.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
01-23-2017, 04:17 PM | #6 | |
Stop the hate, get a V8
3850
Rep 8,625
Bigjae nailed it. I run with Euro MDM at the track and I can smell the rear pads sometimes. Here is a thread where someone had their data logging software overlay individual braking effort on their GoPro footage. You can clearly see the rear brakes being dragged mid-corner to help keep the car on-line: http://www.m3post.com/forums/showthread.php?t=821800 (note, in particular, how long some of the applications are and that it might even brake an individual wheel while you are at WOT) Personally, I am fine with the safety net MDM provides. More rear pad swaps is a small price to pay. You may not need dedicated track pads in the back, but I would definitely go for something more aggressive than an OEM pad. Ferodo DS2500 might work. It will largely depend on how old your rotors are, your driving style, the specific track, ambient temps, etc.
Past: 2011.5 M3 sedan ZCP |
01-23-2017, 08:23 PM | #7 |
11586
Rep 12,726
MDM mostly uses the front brakes, and rarely utilizes the rear brakes. dogbone has shown lots of data to prove this.
Instagram; @roastbeefmike
01-23-2017, 09:05 PM | #8 | |
1571
Rep 8,076
I stand corrected.
01-23-2017, 09:26 PM | #9 | |
11586
Rep 12,726
in an oversteer situation, the outside front brakes are used to reel the rear back in. i'm not sure if it does much in understeer.
01-23-2017, 10:48 PM | #10 |
3850
Rep 8,625
It will lightly brake the inside tires to help pull the car through the corner, yes. You can see this in the above thread I linked, and I have seen it on my own car. On several track days, the wheels on one side of the car have gotten much dirtier than the other side.
Also, remember that EBD uses more rear braking at times to prevent excessive nose-dive (which would cause the rear contact patch to decrease and possibly reduce stability in a corner). If you have the brake pedal to the floor, this is irrelevant, but if you are only using a portion of the pedal travel, it is possible that the car would apply the brakes more heavily in the rear. OP, don't interpret these posts to mean you should run a more aggressive pad in the rear than you have up front. I apologize if this wasn't clear.
ICTZHP25.00 |
01-24-2017, 07:04 AM | #11 |
///M Powered for Life
11489
Rep 10,329
01-24-2017, 07:29 AM | #12 |
1571
Rep 8,076
Well...I learned something today! Thanks!
01-26-2017, 03:17 PM | #13 | |
321
Rep 406
However, I then changed the rears to XR2 pads (OEM were worn down) and I can brake much later, more fun.
ST-60 / MCS 3-way / Solid subframe / Full cage by JPMarketingllc.com / 315-30 square / GT-250 / JPmarketingllc.com Aero Stage2
01-26-2017, 06:54 PM | #14 |
130
Rep 198
Drives: 2011 e90 ZCP
I can't speak to running the combination of track pads in front and OEM in the rear, but I ran two track days on OEM pads and absolutely obliterated the pads and rotors, front and back. I was shocked because I tracked my e46 for years without swapping pads for events.
Your e9x experience may be different, depending on how aggressively you drive. I get that you want to make prepping for each track day as simple as possible, but you have to accept that this car is very heavy and very powerful and you need the right equipment to get the job done. |
01-26-2017, 07:17 PM | #15 |
28
Rep 155
I've run PF08 in the front and Z-rated rears without issues.
01-27-2017, 11:36 AM | #16 |
IG: @dj_dub
1803
Rep 1,452
Drives: 2010 BMW E90 M3 - SG/FR 6MT
I'm gonna be running Carbotech XP20s in the front and StopTech Street Performance pads in the rears in a couple of weeks...hopefully I'll be good with this setup for my driving style at the track. If not, I'll upgrade the rears to Carbotech XP10s.
CarboProject CF Plenum | Dinan CF Intake | ESS Tune | RKP X-Pipe | Akra w/CF Tips | MFactory CF DS | CSF Cooling | AST 5200 | Hotchkis F/R Sways | SPL/Ground Control/Fall-Line Arms | DEFIV Diff Brace | StudioRSR Rollcage | 3-piece BBS RT88 | Michelin PS4S | Brembos F/R | Recaro Profi SPG XL | CAE Ultra Shifter | Perf Elec Wheel V2 | BAVSOUND | GT4 CF Front Lip/Canards/Rear Wing | Arkym CF Rear Diffuser | Forcewerkz CF SS | Varis CF Lower Tray | Turner Skidplate | BayOptiks Headlights
01-27-2017, 02:07 PM | #17 | |
254
Rep 633
Lutfy |
NoCarrier130.00 |
