01-17-2017, 09:53 AM | #1 |
124
Rep 137
Solid subframe bushings with stock diff bushings?
I know this subject has been beat to death, but as title states, anybody running solid subframe mounts with stock diff bushings? 6MT specifically. Seems like not many are doing this.
My car is heading in for a major overhaul, and while it will see track duty, it also will see street and highway driving. I know even the purple and black powerflex transmit a lot of whine. Wondering who has done just the subframe only, and how it is holding up on track? I ran this exact setup on my E46 M3 for years on track with no issues, but the E92 does have a lot more power sent through the drivetrain. Me thinks the solid subframe would help stabilize the diff more, even with OE bushings. Didn't the GTS come with solid sub mounts and stock rubber diff mounts?
'18 GT3 - 6MT
'13 E92 M3 - street/track '07 Cayman S - track car '15 FRS - Sprint racecar '00 Miata - Enduro racecar |
01-17-2017, 01:49 PM | #2 |
5355
Rep 2,806
Drives: '09 E90 M3 - IB
I have a DCT. But I am running solid subframe bushings and stock diff bushings. The car is a dedicated track car. And it's supercharged. It's been fine for over a year.
01-17-2017, 03:19 PM | #3 | |
87
Rep 52
01-17-2017, 03:24 PM | #4 |
1478
Rep 2,672
I haven't gotten there yet but I am planning on the solid subframe and purple powerflex diff bushings. I have read many many posts on this and that seems to be the consensus for DCT cars that are either DD's or see some street and track time. I will also likely swap in the Hotchkis front/rear sway bars at the same time since the rear subframe is already coming down.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
01-17-2017, 04:42 PM | #5 | |
124
Rep 137
I would think the 6MT inherently puts a bit more stress on the bushings than DCT though, but I could be wrong.
'18 GT3 - 6MT
01-17-2017, 07:24 PM | #6 |
3900
Rep 4,165
I have solid subframe with stock diff bushings on DCT. No increase in NVH, and car rides much better, chassis feels like it's one generation newer.
01-17-2017, 07:55 PM | #7 |
11586
Rep 12,726
i'm kinda surprised you didn't do the differential bushings. i feel like you would get even more deflection by focusing those forces on the differential (as opposed to being shared by the differential and subframe bushings). any reason why you didn't? i have the turner derlin and the noise is noticeable, but very subtle. with the windows down, you can't hear it.
Instagram; @roastbeefmike
01-17-2017, 08:03 PM | #8 | |
11586
Rep 12,726
here is a vid of subframe/diff deflection i took. this was before the swap. stuff moves a lot!
01-17-2017, 09:00 PM | #9 |
892
Rep 9,032
We need an after vid!!
Thanks for that vid.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
01-17-2017, 10:32 PM | #10 |
11586
Rep 12,726
thanks, i was going to take an "after" vid, but the way the car feels, i know its not moving around much. a little flexing (like the whole car) i'm sure, but not much). maybe one day when i get bored enough.
aus891.50 |
01-18-2017, 08:32 AM | #12 |
346
Rep 396
In the video the subframe is moving, the diff bushings flex in the direction of the drive axle rotation. My line of thinking was that if you solid mount the diff to the subframe, you are now transferring that work to the subframe bushings, so you'll wear them out faster. I asked AKG about solid diff and poly subframe and they said do matching poly in both the diff and subframe.
01-18-2017, 09:09 AM | #13 | |
11586
Rep 12,726
01-18-2017, 09:15 AM | #14 |
346
Rep 396
I went 75D on the whole drivetrain, would not recommend unless the car is track only
01-18-2017, 09:16 AM | #15 |
124
Rep 137
I don't see it that way. Currently, when you accelerate, the diff pushes/pulls the subframe, and the subframe moves under suspension load too, so in reality you are asking the poor little diff bolts (which are connected to the subframe) to handle both the slop of the diff bushings and the subframe bushing, in multiple directions/axis.
By locking down the subframe, me thinks the diff bushings and bolts are better prepared to do the job they are intended to do, support the diff. Maybe I'm wrong, but I'm fairly sure the M3 GTS used the same arrangement from the factory.
'18 GT3 - 6MT
01-18-2017, 09:42 AM | #16 |
11586
Rep 12,726
The nose of the pumpkin lifts on acceleration.
I would theorize the horizontal diff bolt doesn't see as much stress. It would take a ton of grip to get the pumpkin to rotate horizontally. You would have to have a ton of power and drag slicks. Just my theory. I could be wrong.
01-19-2017, 07:50 AM | #17 | |
///M Powered for Life
11489
Rep 10,329
On the DCT 'track' car, it'll get solid subframe bushings, powerflex street diff bushings (not sure of the color) and the hotchins front and rear sways. Plus MCS 2WNR |
///Mobbin1478.00 |
01-19-2017, 07:55 AM | #18 | |
1478
Rep 2,672
I believe the order of Powerflex's bushing rigidity is yellow -> purple -> black [hardest] and I was originally thinking yellow for the diff bushings but saw they only make purple and black. Hence, purple it is as this car will still be my Friday/weekend car even after the next iteration of track mods.
SYT_Shadow11488.50 |
01-19-2017, 09:08 PM | #19 |
98
Rep 259
I did solid subframe and black powerflex and the diff whine was pretty annoying. I was just driving to and from the track and it was pretty annoying, would not suggest that combo for dd. It did make the car feel better. I am now adding solid motor and transmission mounts but the car will be trailered now so don't really car about NVH.
01-19-2017, 09:26 PM | #20 | |
124
Rep 137
I'm adding Rogue rubber tranny mounts, because those are great, worked nicely on the e46 with very little extra NVH, no annoying noise, just slightly more direct shifting feel and better throttle response. It's a lot of work trying to avoid NVH, but add performance. Almost makes me appreciate the work those factory engineers do.
'18 GT3 - 6MT
01-20-2017, 01:38 AM | #21 | |
175
Rep 513
A local had that setup on his car, he said the whine was very subtle, turning on the radio would mute it already. |
///Mobbin1478.00 |
01-20-2017, 08:11 AM | #22 | |
1478
Rep 2,672
