01-15-2017, 08:13 PM | #1 |
20
Rep 120
AR 390SS quick connect on end of hose
I have the ar 390ss pressure washer, and am trying to add a quick connect socket to the end of the high pressure hose (so I can quickly swap from a lance to a gun). I tried a "standard" M22 to 3/8" socket adapter, but could not get the end of the hose to attach to it--the inner diameter of the adapter was just a bit too small.
Has anyone had success with this? Thanks. |
01-16-2017, 07:31 AM | #2 | |
363
Rep 880
It was kind of tedious Bc it takes a while and you have to make sure you do it evenly. But on the up side it only needs to be like half a millimeter bigger so you don't have to remove that much of the metal.
sb180519.50 |
01-20-2017, 09:38 AM | #5 |
709
Rep 277
Drives: '23 M3 Competition xDrive
I had the same issue. I took my Dremel and sanding attachment and simply spent 2 mins to enlarge the hole. No issues at all and was better than having to track down a new part. Good luck.
2023 Violet Blue/Fiona Red Full - M3 Competition xDrive
@violetblue_m3 |
sb180519.50 |
