12-29-2016, 09:11 PM | #1 |
175
Rep 513
19x10 +25 BBS LM
I'm looking to pick up a set of 19x10 +25 / 19x11 +25 BBS LMs.
I've got an AP Racing Radi-CAL 380MM Front/Rear BBK. Has anybody had any luck running a StopTech ST60 or a BREMBO 380MM on the 19x10 +25 as a Front? BBS says it doesn't clear, but, if it's the matter of adding like a 3MM spacer, that's not a big deal to me. I know somebody previously had a set of 10MM Spacers on the 10 +25 with a 380MM BREMBO, but he said that he used the Spacers for fitment purposes, not for brake clearance, and he never tried to see if they'll clear without the spacer themselves. Just want to make sure before I pull the trigger. I know the 19x9.5 +32 will clear, but, the 10 +25 has a 1/2" Larger Lip, coupled with the fact I can reverse mount it still for another 1/2", which, I believe looks better. Also, allows me to run a 275/30/19 on the 19x10, which I think is a better match than the 19x9.5. Thanks in Advance! |
12-31-2016, 12:25 PM | #2 |
Save the manuals!
6016
Rep 6,747
Be sure to post photos of this wheel setup. That's the fitment all LMs should've come with for this car!
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
BimmerRookie469.00 |
12-31-2016, 07:48 PM | #3 | |
175
Rep 513
BBS has confirmed through their website that the 19x10 +25 DOES clear the OEM Front Brakes. Just, as to whether it clears a BBK, they say no. But, if the matter is something like a 3MM Spacer, that's not an issue at all. Not to mention, my AP RadiCAL Calipers are different than StopTech/BREMBO, so who knows! I'm scheduled for a test fit with my shop next week, they have a 1M there that uses the 19x10 +25 as a rear, so I'll throw that on the front and see how it is. |
01-02-2017, 09:49 PM | #5 |
175
Rep 513
Ohlins R&T on the way.
But, will be test fitting with OEM Suspension, since the coils haven't arrived yet. I actually plan on reverse mounting the 19x10 LMs if they clear, putting them right at about a 19x10 +12 offset in the front. From what I can see, a 275/30/19 with about -3 front camber should clear it just right. |
01-02-2017, 09:51 PM | #6 | |
532
Rep 5,498
Instagram: jellismotorwerks |
01-03-2017, 06:27 PM | #8 |
175
Rep 513
01-03-2017, 09:40 PM | #9 | |
F15 daddymobile
2350
Rep 3,510
01-03-2017, 10:32 PM | #10 |
175
Rep 513
E90s are a bit wider, but, I feel that 20s on the rear of the E90 look a little too large for my liking.
They look fine on the E92s though. The visual aspect of it. 20s also only allow you to run a 255/285 setup, whereas I would like to retain the original 20MM stagger, and I'd also like to run a 275/295 setup also. |
01-05-2017, 01:05 PM | #11 |
92
Rep 211
These HRE's would fit over your brakes. I feel like everyone does LM's, these HRE's would look sweet!
http://www.m3post.com/forums/showthread.php?t=1304786 |
01-06-2017, 10:04 AM | #12 |
1180
Rep 1,658
I know these will clear
www.WheelsBoutique.com || David@WheelsBoutique.com || 786 249 0127 ext. 2109 YouTube Channel: https://www.youtube.com/user/WheelsBoutique |
01-06-2017, 10:29 AM | #13 |
175
Rep 513
01-06-2017, 09:50 PM | #15 |
F15 daddymobile
2350
Rep 3,510
^ yes!! can't wait to see them!
01-06-2017, 09:56 PM | #16 |
175
Rep 513
I'm debating on the 10s still.
19x11 +25 come factory reverse mounted from BBS 19x10 +25, does not come factory reverse mounted from BBS. I test fitted it today, a reverse mounted 19x10 +25, which puts it at about 19x10 +12 offset. I'm worried that it won't fit with 275/30/19 Michelin PSS on the fronts. I have Ground Control Camber Plates & Ohlins R&T on the way. I don't mind running -3 up front...but any thoughts? I want to believe that it'll fit, but, it seems like it's going to be quite tight/close. |
01-12-2017, 11:50 PM | #19 |
60
Rep 277
I have the exact same wheel set up, 19x10/19x11 +25 all around. Not sure how the Ohlins are but the 19x10 +25 rubbed my KW Clubsport spring and spring perch, up front. 5mm spacer fixed that. But just giving you a heads up, you may or may not run into that issue.
01-18-2017, 06:21 AM | #20 |
24
Rep 206
This is probably a dumb question. But what do you guys mean when you say reverse mount the wheel? And why would you want to do this?.... just trying to learn
01-19-2017, 02:50 AM | #21 | ||
175
Rep 513
As for those wonder if it's safe, BBS actually sells certain configurations in this fashion. The 19x11 +25 is reverse mounted from factory. |
01-20-2017, 02:11 PM | #22 |
24
Rep 206
thanks for the explanation.... that make sense now.
Did you get the wheels mounted yet? any pics?
2010 E90 DCT:
2011 E92 DCT:-- sold |
